The data dictionary says character...but..so does the reference field as
well, and this has no trouble plugging into the reference field. It
updates just fine. The value would normally range from 1 to 10...
POLINE is (x)5 for size.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Blake Clemens
Sent: Monday, November 23, 2009 1:03 PM
Subject: RE: [Vantage] service connect
Is that the normal formatting for that field?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Behalf
Of Rob Bucek
Sent: Monday, November 23, 2009 1:59 PM
An integer...the schema has it labeled as an unsigned byte.
Rob Bucek
FAX: (715)284-4084
Behalf
Of Blake Clemens
Sent: Monday, November 23, 2009 12:58 PM
What kind of value are you trying to place in there?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Rob Bucek
Sent: Monday, November 23, 2009 1:52 PM
Subject: [Vantage] service connect
Has anyone here had any trouble updating the POLINE field in the
orderdtl table through a service connect workflow? This has me
completely baffled... I see the data in the conversion, then after the
web method its just gone. I did a simple remap to the reference field
and that works just fine, but not when I try and place a value in the
POLINE.
Rob Bucek
FAX: (715)284-4084
Rob Bucek
FAX: (715)284-4084
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Rob Bucek
POLINE.
Rob Bucek
FAX: (715)284-4084
