Service PRO issue
Has anyone see this error when trying to install Service pro integration. We are currently on prem.
Ice.Common.EpicorServerException: Could not load file or assembly ‘Fsisp.Data.Model, Version=10.2.700.0, Culture=neutral, PublicKeyToken=476c49c300052a33’ or one of its dependencies. The system cannot find the file specified. —> System.IO.FileNotFoundException: Could not load file or assembly ‘Fsisp.Data.Model, Version=10.2.700.0, Culture=neutral, PublicKeyToken=476c49c300052a33’ or one of its dependencies. The system cannot find the file specified.
at Extensibility.FSI.ServicePro.CompanyExtender.UpdateSendToFSAFalse(String company)
at Extensibility.FSI.ServicePro.CompanyExtender.BeforeMethod(String methodName, IDictionary2 parameters) at ConcreteClass30.BeforeMethod(String , IDictionary2 )
at Erp.Services.BO.CompanySvcFacade.Update(CompanyTableset& ds) in C:_releases\ERP\ERP10.2.700.14\Source\Server\Services\BO\Company\CompanySvcFacade.cs:line 3277
at SyncInvokeUpdate(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_releases\ICE\ICE3.2.700.14\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:_releases\ICE\ICE3.2.700.14\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
— End of inner exception stack trace —
Or this meessage.
Unable to reach the server. Retrying…
System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘00:00:59.9980010’. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing)
Server stack trace:
at System.ServiceModel.Channels.SocketConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
at System.ServiceModel.Channels.DelegatingConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
at System.ServiceModel.Channels.ConnectionUpgradeHelper.InitiateUpgrade(StreamUpgradeInitiator upgradeInitiator, IConnection& connection, ClientFramingDecoder decoder, IDefaultCommunicationTimeouts defaultTimeouts, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.SendPreamble(IConnection connection, ArraySegment`1 preamble, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.DuplexConnectionPoolHelper.AcceptPooledConnection(IConnection connection, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open()
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at System.ServiceModel.ICommunicationObject.Open()
at Epicor.ServiceModel.Channels.ChannelEntry1.CreateNewChannel() at Epicor.ServiceModel.Channels.ChannelEntry1.CreateChannel()
at Epicor.ServiceModel.Channels.ChannelEntry1.GetContract() at Epicor.ServiceModel.Channels.ImplBase1.GetChannel()
at Epicor.ServiceModel.Channels.ImplBase`1.HandleContractBeforeCall()
at Fsisp.Proxy.BO.FSIServiceProImpl.TestConnection() in C:_Releases\ERP\CurrentFSI\Extensibility\FSI\ServicePro\Source\Shared\Contracts\BO\FSIServicePro\FSIServiceProImpl.cs:line 56
