Set BPMContext fields from external application
I am trying to use a .Net application to integrate into Epicor. For one of the tasks we need to populate a UD field on PartTran when there is a misc issue / return. I have added the UD field to the PartTran table and re-generated the data model however the UD field is not available to populate in the IssueReturnDataSet. As a workaround i am trying to put the data into a BPMContext field and will copy it to PartTran in a BPM. However i have no idea how to access the BPMContext data from an external application. (I can get the IssueReturn BO and issue and return misc material the bit missing is populating the PartTran UD field.
Just to clarify - I assume you are using the E10 client dlls and going through the Impls?
( Or SOAP? Or REST?)
The BPMContext dataset is serialized between client and server as a Message Header. Depending on how you do the integration, the access to that header varies.
Yes I am using the client dlls.
We plan to upgrade to 10.1.600 soon and some time after that i want to change our integrations to use REST but that is for another day :slight_smile:
Brett
Here is an example of passing in BPM Data from an External call to a BO
  using (var dynQry = GetEpicorBOInstance<DynamicQueryImpl, DynamicQuerySvcContract>(binding, new Uri($"https://{Settings.Default.Server}/{Settings.Default.Instance}/ICE/BO/DynamicQuery.svc"), Settings.Default.UserName, Settings.Default.Password))
                    //Instanciate Date Context Data Set
                    dynQry.BpmContext = new Ice.Bpm.Context.ContextDataSet();
                    //Create BPM Data Row
                    var bpmDataRow= dynQry.BpmContext.BpmData.NewBpmDataRow();
                    //Set Fields
                    bpmDataRow.SysRowID = Guid.NewGuid();
                    bpmDataRow.Character01 = "MYChar01";
                    //Insert into BO
                    dynQry.BpmContext.BpmData.AddBpmDataRow(bpmDataRow);
                    var eP = dynQry.GetQueryExecutionParametersByID(args[0]);
                    bool morePages;
                    var rslt = dynQry.GetListByID(args[0], eP, 0, 0, out morePages);
                    foreach(DataRow r in rslt.Tables["Results"].Rows)
                        r["RowMod"] = "U";
                    dynQry.UpdateByID(args[0], rslt);
Once again, Thanks Jose :slight_smile:
