Set default field NextActionID
Hi all,
I’m trying to create a bpm to set the default field NextActionID to “DeptHead”. But why is it that when I try to run it , bpm has no effect at all on the field that has been on set? Is it because the field is in the requisition dispatching?
I need help, thank you.
