Set FreqCode for MiscCharge
Hi everyone,
I want to change the default FreqCode from ‘E’ (every) to ‘L’ (last) on the QuoteHed MiscCharge entry screen. I have tried using the widgets in Data Directive but so far have not been able to do it.
Any help much appreciated
I would trace the process in the UI. My thought is then to look at method directives rather than data directives, probably looking at a method similar in name to GetNewQuoteHed I would suggest, but again you’d find that by doing a trace.
Create Post-Processing BPM on Erp.Quote.GetMiscChrgDefaults and update ttQuoteHedMsc.FreqCode field to L
Thanks guys,
@Arul That worked perfectly. Thank you very much!
