You can set your Company in the top-level CompanyID node like this:
CompanyID=COMP;PlantID=PLNT
Where COMP and PLNT are your Company and Plant IDs respectively.
In the actual InventoryQtyAdjDataSet just set your Company to your Company
ID (e.g. ³COMP²).
-bws
ID (e.g. ³COMP²).
-bws
On 2/20/09 3:18 PM, "Charlie Wilson" <foamdesigncsw@...> wrote:
> I¹m working with InventoryQTYADJ and it doesn¹t have an option to specify
> plant.
> ~Charlie
> ________________________________________
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
> Of
> bw2868bond
> Sent: Friday, February 20, 2009 3:05 PM
> Subject: [Vantage] Re: Set Plant In SC
> When you are in the XML mapper in your conversion properties, your
> web method is on the right. Each one requires you to set the Company
> ID at the top of the method - that is where you can specify plant
> etc...
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Charlie
> wrote:
>> > When I run trace during a plant change it shows
> sessionmanager.setplant but
>> > this method does not show up on the list of methods I can import.
>> > ~Charlie
>> > _____
> Behalf Of
>> > Charlie Wilson
>> > Sent: Friday, February 20, 2009 2:39 PM
>> > Subject: RE: [Vantage] Re: Set Plant In SC
>> > Okay I see what I need to do but where is this connection string the
>> > document is rather vague.
>> > ~Charlie
>> > _____
>> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
>> > [mailto:vantage@yahoogroups <mailto:vantage%
> 40yahoogroups.com> .com] On
>> > Behalf Of
>> > bw2868bond
>> > Sent: Friday, February 20, 2009 1:45 PM
>> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
>> > Check out pages 33 and 34 in the webservices developers guide in
> the
>> > webservices folder on your server
>> > There are al sorts of nifty parameters that can be specified.
>> > --- In vantage@yahoogroups <mailto:vantage%
> 40yahoogroups.com> .com, "Charlie
>> > Wilson" <foamdesigncsw@>
>> > wrote:
>>> > > Can I set what plant I am working in from a SC? If so how.?
>>> > > ~Charlie
>>> > > [Non-text portions of this message have been removed]
>> > No virus found in this incoming message.
>> > Checked by AVG - www.avg.com
>> > Version: 8.0.237 / Virus Database: 270.10.23/1951 - Release Date:
> 02/20/09
>> > 07:26:00
> 02/20/09
>> > 07:26:00
