Thanks Rick, it worked perfectly.
Now I have the challenge of logging as every user and two different databases to distribute the change, it will take awhile.
Justin
Justin
--- In vantage@yahoogroups.com, "that_guyy" <rbird@...> wrote:
> Create a 'Default' Named Search for each user (since Named Searches are user specific, like a personalization):
> 1. Open Customer Maintenance
> 2. Click on the 'Customer' Button or the binoculars icon do open a search.
> 3. Click on the 'Named Search' button
> 4. Once the 'Named Search Options' window opens select the New Icon to create a new Named Search.
> 5. Give the Named Search a ID & Description (ID cannot contain spaces), somethink like Default and Default All Customers
> 6. Leave the Search Type to 'Basic Search'
> 7. Notice that a sample of the search criteria is displayed, set the default settings for this Named Search (Set Customer Type to '<ALL>')
> 8. Select the 'Options' tab and check the box that is labeled 'Default'
> 9. I suggest also unchecking 'Return All Rows' and enter >=100 in the Maximum Rows Returned field.
> 10. Click 'Save' and close out of the windows until you are back at the Main Menu. Now open up the program and bring up the Search, you should have <ALL> defaulted.
> This will need to be applied per user
