Set TextBox format or mask (V 8.03.409C)
I was hoping there was a way to set the textbox object to do all that for me.  Guess I'll have to code it.
Thanks for the link too.
Calvin
I need to store a 5 digit code as a string, so I'm using ShortChar02, but need to limit input to a 5 character numerical code.
Why not use a number instead, you ask?  Because future codes may contain letters.
So I need to limit the string entered to 5 numerical characters.  For example:
Good values: '00000' , '12345', '00101', '98765', etc ...
Bad values: '0', '1234', '1234A', '123456', '12-34', etc...
Any way to set an input mask on a EpiTextBox?
Or must I use code to check the length and for valid characters?
Thanks in Advance,
Calvin
P.S. Version 8.03.409C
There are a number of ways but the most basic thing to remember is the EpiTextBox is basicly a .net textbox and any routines that would validate text can be used.  A quick google will result in many different approaches from using keypress to text change and validating events.  Here is a random one as an example,
http://stackoverflow.com/questions/9969824/vb-net-need-text-box-to-only-accept-numbers
You can also put a field change event on the associated field or a BPM that checks the values when a save is attempted.
Jim Kinneman
Encompass Solutions, Inc
