Setting a form field to "display only" in V8
This technique worked perfectly. Thanks.
--- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@...>
wrote:
> --- In vantage@yahoogroups.com, "Brad Feazell" <Brad_feazell@>
> wrote:
> Try doing it using the form event wizard.
> Choose the Event type Load and then update the code.
> In the script editor put the following code in
> under the event.
> It seems to work for me I don't know what your situation is though.
> Dim OrderDtl As EpiDataView = Ctype (oTrans.EpiDataViews
> ("OrderDtl"),EpiDataView)
> OrderDtl.dataView.Table.Columns("Date01").ExtendedProperties
> ("Enabled")= False
> End Sub
> > It works fine until I save the customization, shut down Vantage,
> fire
> > it back up again and the enabled property reverts back to TRUE.
Is
> > there a way to make it stick?
> > --- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@>
> > wrote:
> > > Hi Brad,
> > > Yes, you need to set the enabled property of the
> object
> > to
> > > false. This will achieve the correct result. Do this on the
> > properties of
> > > the new text box you have bound to the date01 field.
> > > Regards,
> > > Stephen Edginton
> > > _____
> > > From: Brad Feazell [mailto:Brad_feazell@]
> > > Sent: Thursday, August 10, 2006 4:47 PM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Setting a form field to "display only" in V8
> > > I customized the ORDERDTL.DATE01 field onto the Order Entry
form,
> > > (Lines Tab) but I want it to be display-only. Setting the
> ReadOnly
> > > property to TRUE doesn't do it and there doesn't appear to be
an
> > > obvious way.
> > > The "On Hand" field on the same tab appears exactly the way I
> want
> > > Date01 to appear - basically greyed out with no ability to
touch
> > the
> > > data in the field.
> > > Can you use customization to do this?
> > > Checked by AVG Free Edition.
> > > Version: 7.1.405 / Virus Database: 268.10.8/415 - Release Date:
> > 09/08/2006
> > 09/08/2006
I customized the ORDERDTL.DATE01 field onto the Order Entry form,
(Lines Tab) but I want it to be display-only. Setting the ReadOnly
property to TRUE doesn't do it and there doesn't appear to be an
obvious way.
The "On Hand" field on the same tab appears exactly the way I want
Date01 to appear - basically greyed out with no ability to touch the
data in the field.
Hi Brad,
Yes, you need to set the enabled property of the object to
false. This will achieve the correct result. Do this on the properties of
Regards,
Stephen Edginton
_____
obvious way.
data in the field.
Version: 7.1.405 / Virus Database: 268.10.8/415 - Release Date: 09/08/2006
It works fine until I save the customization, shut down Vantage, fire
it back up again and the enabled property reverts back to TRUE. Is
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> Hi Brad,
to
properties of
> Regards,
> Stephen Edginton
> _____
> From: Brad Feazell [mailto:Brad_feazell@...]
> obvious way.
the
> data in the field.
09/08/2006
09/08/2006
I usually set the control to ReadOnly = true
EpiKeyField = false
Enabled = false
and even then, there seems to be no guarantee that it will come back the
way you want.
I have set fields like that and invisible too. When you open the form in
developer mode it works fine. When you open the form in run mode it is
fine. when you enter new data in the form it is fine but when you open
existing data the control reverts back to being enabled, visible.
Good Luck,
Bernie.
Of Brad Feazell
Sent: Friday, August 11, 2006 3:40 PM
Subject: [Vantage] Re: Setting a form field to "display only" in V8
wrote:
> Hi Brad,
to
properties of
> Regards,
> Stephen Edginton
> _____
> obvious way.
the
> data in the field.
09/08/2006
09/08/2006
--- In vantage@yahoogroups.com, "Brad Feazell" <Brad_feazell@...>
under the event.
("Enabled")= False
End Sub
fire
> wrote:
> > Hi Brad,
object
> to
> properties of
> > Regards,
> > Stephen Edginton
> > _____
ReadOnly
> > obvious way.
want
> the
> > data in the field.
> 09/08/2006
> 09/08/2006
wrote:
I am sorry you could also try ExtendedProperties("ReadOnly")= True
> under the event.
> ("Enabled")= False
> End Sub
> fire
Is
> > wrote:
> > > Hi Brad,
> object
> > to
> > properties of
> > > Regards,
> > > Stephen Edginton
> > > _____
form,
> ReadOnly
an
> > > obvious way.
> want
touch
> > the
> > > data in the field.
> > 09/08/2006
> > 09/08/2006
I've run in to occasions where setting the attributes as described below doesn't work. And fields set as invisible appear when other fields have changed value. Dragging the fields off the sheet works.
----- Original Message -----
Sent: Friday, August 11, 2006 1:10 PM
Subject: RE: [Vantage] Re: Setting a form field to "display only" in V8
EpiKeyField = false
Enabled = false
way you want.
Good Luck,
Bernie.
Of Brad Feazell
wrote:
> Hi Brad,
to
properties of
> Regards,
> Stephen Edginton
> _____
> obvious way.
the
> data in the field.
09/08/2006
09/08/2006
