Setting a numeric bound text box not to show 0
Just wondering how one would go about setting the value of a text box bound to a numeric field to not show the 0 when adding a new record on a UD form?
Users struggle to either double click to select the whole field or delete the 0 when entering in data :slight_smile:
I think the last time this came up, the suggestion was to make it a text field and cast the data to a number when needed.
https://epiusers.help/t/remove-0-from-numeric-fields/50689
Thanks Aaron, I was thinking of that, and hoping there was a bit cleaner of a method. I was sort of hoping it would have been ok after the get new, then change the textbox.value to ā€œā€
Why is it I can never find these things when I am looknig… Thanks.
It took me a couple of goes, but I knew for a fact it was there somewhere in this case, because I remembered reading it! That always helps.
Notice the current live discussion on ā€œNull value within Quantity fieldsā€, which seems like it’s close to what you’re wanting to do, too.
Hint: Google search is sometimes better at finding a post here than the on-site help. That’s no shade on the team here at E10Help just the power of the Google.
Adding site:epiusers.help to the google search will limit Google’s results to this domain.
I use this on lots of sites. Especially ā€œpoorā€ ones (like sites ending with .gov and .edu :wink: )
Yeah, forgot to mention that, that’s what I get for assuming everyone already knew that. :wink: Thanks @ckrusen
