Setting Password Character
Replace 'UltraTextEditor' with the name of the control on the form. For example, I made two textboxes on the Quote form use a "password character" when text is entered.
In the Form_Load function...
txtEpiCustom1.PasswordChar = "*"
txtDrawing.PasswordChar = "X"
txtEpiCustom1 is a textbox I added. Text shows up as '*' as its typed.
txtDrawing is the original textbox where you'd enter the Drawing# for the line item. Text shows up as 'X' as its typed.
Calvin.
--- In vantage@yahoogroups.com, "CarlH" <carl.heeder@...> wrote:
> I'm trying to set a character to fill if a field is used as a password.
> So far I've got the following but somethings are missing.
> Private Sub AbcCodeForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles AbcCodeForm.Load
> UltraTextEditor.PasswordChar = "*"
> '// Add Event Handler Code
> End Sub
> Help...
End Sub
Help...
