Here's an idea.
open vantage.ini, fix it, and create a file called safevantageinifile.ini.
make a file in notepad with the following lines
REM deleting last backup
del v:\vantage.in_
REM backing up vantage ini file
ren v:\vantage.ini vantage.in_
REM copying correct vantage ini file to vantage.ini
copy v:\safevantageinifile.ini vantage.ini
REM substitute v: with the name of your mapped vantage drive letter
name it inifix.bat, stick it in the vantage directory, put a shortcut on
your desktop if you wish.
run it after client setup is run.
secure safevantageinifile.ini , inifix.bat , and vantageclientsetup with NT
permissions.
Best Regards,
Thaddeus
Sent: Tuesday, October 09, 2001 12:18 PM
Subject: RE: [Vantage] Setup Overwrites Vantage.vtg
We have the same problem in 3.0. Not only does it overwrite during a client
setup, but also at random times throughout the day. We have custom
programming as well and it can be weeks since I've done a client install but
still have to go to the server and replace the vantage.ini file often
because custom programming doeesn't work.
Rick
del v:\vantage.in_
permissions.
Best Regards,
Thaddeus
Rick
