Shape Customization
If you want to modify existing screen(or form) it's not possible. If
you'd like to create new form to see your user-defined fields the
best way to learn it is go to Vantage Help, then switch to Index and
type "vb form"
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
wrote:
> No, I am customizing a screen within Vantage. I wanted to put in a
> shape on the screen similar to what some screens do to show you the
> status of different items. For instance, the order master has one
to
> show if the customer is on hold or not. I can insert a shape but i
> can't put any text on it.
> --- In vantage@yahoogroups.com, "talanaky" <talanaky@> wrote:
> > You mean that you inserted text object in your Crystal report and
can
> > not edit its content?
<laidig.systems@>
> > wrote:
> > > I am trying to put text on a shape but haven't been very
successful.
> > > There is a field to type in text but nothing appears on my
shape. Is
> > > there something that I need to do so that text appears on the
shape?
> > > Thanks.
I am trying to put text on a shape but haven't been very successful.
There is a field to type in text but nothing appears on my shape. Is
there something that I need to do so that text appears on the shape?
Thanks.
You mean that you inserted text object in your Crystal report and can
> Thanks.
status of different items. For instance, the order master has one to
> --- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@>
> > Thanks.
