Thanks all.
Epicor sent a utility program which changes any Parts that have
1. Lot tracking activated
2. Have a blank lot reference.
The utility adds "UNKNOWN LOT" to the lot reference of those parts and allows you to zero out the eroneous bin quantity.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
To: vantage@egroups.com
Sent: Tuesday, November 28, 2000 7:42 AM
Subject: [Vantage] Re: Shipment from non-existing bin
Vladimir,
I was wondering if you found a solution to your problem with a
negative onhand in a nonexistant bin. We just came across the same
situation (Vantage 3.0). Could you share what you did to fix this?
Troy Funte
Liberty Electronics
--- In vantage@egroups.com, "Tim Care" <ecfmis@e...> wrote:
> We've actually had this as well, where a part was
> in inventory, but didn't have a bin. If you call
> Vantage support, they have a utility that will go through
> all inventory, and fix the problem. It was a while ago,
> and I don't remember exactly what the fix was, but
> it did clear the problem. Good luck.
> Tim Care
> Electro Chemical Finishing
> From: "Vladimir Tigay" <vtigay@w...>
> To: "OneList" <vantage@egroups.com>
> Sent: Wednesday, November 22, 2000 10:29 AM
> Subject: [Vantage] Shipment from non-existing bin
> > This is a situation:
> > When shipping parts, shipper did not specify Bin number. I do not
> > understand how Vantage allowed this to happen, but, anyway, now I
have
> > negative quantity associated with non-existing bin. This
quantity is
> added
> > to (actually, "subtracted from" since it's negative) existing
quantity on
> > hand, returning wrong number. I cannot adjust the quantity
because the
> bin
> > does not exist.
> > Do you have any idea how to fix the situation?
> > Vladimir Tigay
> > WLS Stamping Co.
eGroups Sponsor
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
