Shipping Labels
We are wondering about what everyone uses for software for shipping labels.
Is there software out there that can be used with Vantage, or is there some
other third party software that can do this? Each of our customers would
like a different format of barcode. Certain things on one line, length of
the bar code etc. Any feedback on this will be greatly appreciated
Justin Sorenson
Network Administrator
Wire Maid Manufacturing Ltd.
PO Box 169
2714 Ross Avenue
Schofield, W 54476
Phone: (715) 359-0545
Fax: (715) 355-1353
Email: Justin@...
We use Loftware's LLM product, and are happy with it.
George Brockman II
Gasket Engineering
Sent: Wednesday, December 06, 2000 8:13 AM
To: 'vantage@egroups.com'
Subject: [Vantage] Shipping Labels
labels.
there some
would
length of
Justin Sorenson
PO Box 169
2714 Ross Avenue
Schofield, W 54476
Fax: (715) 355-1353
Email: Justin@...
-------------------------- eGroups Sponsor
We no longer allow attachments to files. To access/share Report
Files, please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try
it, go to www.egroups.com, login and be sure to save your password, choose
My Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
You can do this with the Crystal Reports shipping label in
Vantage. Set up certain fields to print based on the
customer ID or any other field. It'll take some effort
to set up but will work pretty good.
> Justin Sorenson
> PO Box 169
> 2714 Ross Avenue
> Schofield, W 54476
> Fax: (715) 355-1353
> Email: Justin@...
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
We use Easylabel software. It works pretty good! We don't have it
interfaced with Vantage or anything. And, we just found out that GM is
going to require 2-D labels and our software is already capable of doing it!
We just need a different scanner.
Wendy Pursche
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
----- Original Message -----
To: <vantage@egroups.com>
Sent: Wednesday, December 06, 2000 9:13 AM
labels.
some
> Justin Sorenson
> PO Box 169
> 2714 Ross Avenue
> Schofield, W 54476
> Fax: (715) 355-1353
> Email: Justin@...
Justin -
We use Report Builder.
We reviewed the requirements of all the customers demanding bar
coded labels. Then generated our own label which was comprised
of all the client's needs.
HTH,
Calvin
labels.
some
> Justin Sorenson
> PO Box 169
> 2714 Ross Avenue
> Schofield, W 54476
> Fax: (715) 355-1353
> Email: Justin@...
Joe Konecny wrote:
"You can do this with the Crystal Reports shipping label in
to set up but will work pretty good."
We do this exact thing at Camcraft - works very well. We make liberal use of
"if" statements to give us conditional printing for different customers.
Jim O'Donnell
Camcraft
labels.
some
> Justin Sorenson
> PO Box 169
> 2714 Ross Avenue
> Schofield, W 54476
> Fax: (715) 355-1353
> Email: Justin@...
How are people creating bar coded shipping labels? We would like to print
bar coded labels with part#, po# and quantity to put on poly bags which
would contain the parts and then pack the bags in a box. Trying to eliminate
the keying in by warehouse personnel but still be able to make quick changes
for quantity. Usually a 1,000 to a roll but this time we have 1,100 or
shipping 2,500 with two rolls of 1,000 and one roll of 500. Any ideas?
Perhaps a VB form or a subreport? Any input would be beneficial. We do have
Label Matrix and Bar Tender printing software in house already. We are
running Vantage/eManufacturing 3.00.632 Progress 8.3. Thanks in advance for
the help.
Jim Frice
Assistant Controller
William Frick & Company
730 Forest Edge Drive
Vernon Hills, IL 60061
PH: 847-634-6341 EXT. 151
FAX: 847-634-2233
E-Mail: Jim.Frice@...
Jim,
We are using a product from a company called Loftware. I've used it
for creating shipping labels that draw data from Vantage via ODBC. I've
also used it to create bar coded key sequences for logging in and out of
Vantage.
Bart Sgroi
Sent: Wednesday, June 27, 2001 10:07 AM
To: Vantage@Yahoogroups. Com
the help.
Jim Frice
FAX: 847-634-2233
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Label Matrix, Custom Progress App, Custom Visual Basic App and a Zebra
printer.
1) The shipping dept. executes the Progress program from within Vantage
(added menu item).
2) The progress program list all current open packing slips. Shipping
person selects the packing slip no that he needs labels for and clicks the
print button.
3) All required data is extracted from Vantage and placed on the hard disk
in a text file.
4) The program then launches the Visual Basic program which reads the text
file and creates a DBF file.
5) The Visual Basic program then executes the Label Matrix print routine
using the newly created DBF file and the label format selected from the
Vantage Customer VB form field, and the labels are printed off the zebra
printer.
Michael Podlin
Sent: Wednesday, June 27, 2001 9:07 AM
the help.
Jim Frice
FAX: 847-634-2233
Sweet stuff, Mike!
Sent: Wednesday, June 27, 2001 9:45 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Shipping Labels
printer.
(added menu item).
print button.
in a text file.
printer.
Michael Podlin
the help.
Jim Frice
FAX: 847-634-2233
Jim,
I've created a progress program that runs from an icon that allows
shipping department to enter job and heat number, user presses print,
and a report builder report is called which prints the box label.
Any customer info, part info, order info, etc. from any table in
Vantage that can be related from jobhead can currently be placed on
the report. The program can be modified to allow quantities for each
label or prompt the user for whatever.
This is currently printed on a full sheet with peel-off adhesive back.
Bar code 39 could be used if this is what your situation requires.
I've done the same for a custom shipping pick list and labels for the
receiving warehouse.
Feel free to contact me off list if you would like a screen snapshot.
Lonnie Drew
Southern Tool, Inc.
256-831-2811 ext 243
lonniedrew@...
ldrew@...
print
which
eliminate
quick changes
or
ideas?
do have
are
advance for
> the help.
> Jim Frice
> FAX: 847-634-2233
> E-Mail: Jim.Frice@f...
Is anybody using a Crystal Report to print Shipping Labels on a
DataMax label printer? To me, it doesn't look like the form included
w/ Vantage can be customized to print on an actual label printer.
Has anybody found a way to do it?
Thanks!
Ryan M. Rindler
Norwood Tool Company
We use Crystal to print Shipping lables to a Zebra ZM4 printers, I wound up
creating my own crystal format, eventually we'll be printing AIAG barcodes
for packaging I anticipate that it will be done with a compiled Crystal
Report. (Does anyone know if version 5.2 has a multi report selection
feature similar in nature to the Ceasar utility)
Shirley
Sent: Thursday, June 13, 2002 11:06 AM
Thanks!
Ryan M. Rindler
Ryan,
We are using Zebra 105Se label printer to print Shipping Labels. If you want
to I can e-mail you the .rpt file
I had to create it from scratch.
Mike Tonoyan / All American Products Co.
miket@...
To: <vantage@yahoogroups.com>
Sent: Thursday, June 13, 2002 8:06 AM
> Thanks!
> Ryan M. Rindler
Mike,
I would really appreciate it if you would send that .rpt file to me
(rrindler@...). Thank you very much!
Ryan
Rather than use crystal label templates, try setting up the report to be a
standard report. You can then select your label printer, and paper/label
size just as you would if you were printing to any other printer. The
report design area will resize to match the label size.
Thaddeus Jacobs
Information Solutions Developer
Kinematic Automation, Inc.
mailto:tjacobs@...
Sent: Thursday, June 13, 2002 8:41 AM
Subject: Re: [Vantage] Shipping Labels
Ryan,
miket@...
> Thanks!
> Ryan M. Rindler
Thanks for the suggestion, Thad. I will give that a try also.
Ryan
to be a
paper/label
The
> Thaddeus Jacobs
> mailto:tjacobs@k...
> From: Mike Tonoyan [mailto:miket@a...]
> To: vantage@y...
> Ryan,
you want
> miket@a...
> From: "rmrindler" <rrindler@n...>
> To: <vantage@y...>
included
> > Thanks!
> > Ryan M. Rindler
must
access. )
Builder and
must have
Builder and
We are doing this (unfortunately) with RB reports. It was extremely easy to setup to print to a Zebra label printer as if it is a laser printer. No special coding required. Bar codes are Code 39 and the few requests for Code 128 have been successfuly granted a waiver on that. Most scanners can scan almost any code.
The various label formats are all on a report sub-menu in the Shipping menu branch. Some are driven by SO #, Line and Rel but a few are based on Packling Slip. Main problem with PS is we often box stuff up long before the PS has been generated. A couple customers require a special label on the PS in addition to box labels. As long as we were doing the labeling we now label everything and if there is not a custom label we have a generic version.
The label reports take advantage of passing parameters such as box count from the filters. Most parts have a std qty per carton on the part master but if the filter value is <> 0 it overrides the standard (in case a partial box fills out the release).
Someday I will have to convert this all to Crystal but until then it works great. New requests are often similar to an existing flavor so I can clone it off and make a new one pretty quickly.
-Todd C.
Sent: Wednesday, June 02, 2004 11:15 AM
I was wondering how other companies are using Vantage to produce "custom"
shipping labels for customers. We have more and more customers that want
their shipments bar coded with all kinds of information. Most of the
customers that have asked for this have a low volume of shipments and we
just made a form in Excel that the shipping guy had to re-key information
into then print the label. Currently I have someone we ship to three to
four times a week asking for a complicated bar code label. I'd like to pull
the information from Vantage and have the labels print when the shipment is
packaged. Does anyone have any ideas? My programmer says he can modify the
program and add a crystal report to the end of the print routine to spit out
the label, but I hate making program changes.
Paul Lipham
ASPI
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=129o3vcs6/M=295196.4901138.6071305.3001176/D=groups/S=1705007183:HM/EXP=1086279313/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=391937085>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Hello All,
Has anyone run into the following issue with printing shipping labels on a Zebra label printer:
Blank extra label always printed after each populated label?
We are running 6.1 and using a Zebra 105S label printer with 4x6.5 inch labels. Problem started immediately after our upgrade to 6.1 from 5.0.
Pulling up the rpt in Crystal seems to show that the report was created and layed out for a 8.5x11 page. But everytime I change the printer configuration to the Zebra or play with the orientation no data will preview.
Looking forward to your suggestions.
Charles
One thing you need to specify the actual printer in print set up. Printers
have a library of sheet sizes they can use. If the specific printer name
its going to print on is not specified crystal will default to the default
printer of the computer that Crystal is running on. Also are there any sub
reports as part of the label. I completely ditched the stock label for my
own.
Shirley
_____
Sent: Thursday, March 24, 2005 10:46 AM
Hello All,
preview.
Charles
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129aasnmi/M=298184.6191685.7192823.3001176/D=gr
oups/S=1705007183:HM/EXP=1111765582/A=2593423/R=0/SIG=11el9gslf/*http:/www.n
etflix.com/Default?mqso=60190075> click here
<http://us.adserver.yahoo.com/l?M=298184.6191685.7192823.3001176/D=groups/S=
:HM/A=2593423/rand=291925011>
_____
Yahoo! Groups Links
Tracking #: 5ABDECDD741B47498E9359220FCABC9A20B7E4B0
