Shop Load Capacity
I have resources associated with each resource group. However, some of my resources are essentially the same, like 3 machines that are all the same kind or 5 hand drills. Can't I say I have a resource with 3 machines? Do I have to define three separate resources like machine 1, machine2, etc.?
--- In vantage@yahoogroups.com, "CharlieSmith" <CSmith@...> wrote:
> Each resource group has to have at least one resource (In V6 it was the
> machine). Once you have the resources in the group you should be able to
> generate capacity. To modify capacity, modify the calendars associated
> with the group or the resource.
> Charlie Smith
> 2W Technologies LLC, Sr. Business Consultant
> Phone: (312) 533-4033 x8046
> (860) 620-9553
> Fax: (847) 374-3620
> 2W Tech on Facebook
> <http://www.facebook.com/pages/Chicago-IL/2W-Technologies-LLC/1391945694
> 32409> www.2WTech.com <http://www.2wtech.com/>
> Of greg_clauser
> Sent: Tuesday, January 31, 2012 3:39 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Shop Load Capacity
> I'm familiar with Vantage 6.x but it's been a year or two. Now setting
> up things in 9.05.607. Pretty much got the Operations, Departments,
> Resource Groups, Resources, and Shop Calendars set up correctly I think
> but I'm now a little stumped.
> I see on the shop load report that Resource Group basically replaced
> Work Center from Vantage. I think I could define machines in Vantage or
> just specify that a certain work center contained x number of machines.
> Therefore a workcenter with 3 machines and a 7.5 hour shift would show a
> capacity of 22.5 hours per calendar day shift.
> In E9 I have resources under resource groups and I run this utility
> "Generate Shop Capacity Process" but my shop load report does not update
> the resource group capacities.
> A)- What am I missing?
> B)- Is there a place to enter the number of resources I have of any one
> kind like I used to do with machines?
I'm familiar with Vantage 6.x but it's been a year or two. Now setting up things in 9.05.607. Pretty much got the Operations, Departments, Resource Groups, Resources, and Shop Calendars set up correctly I think but I'm now a little stumped.
I see on the shop load report that Resource Group basically replaced Work Center from Vantage. I think I could define machines in Vantage or just specify that a certain work center contained x number of machines. Therefore a workcenter with 3 machines and a 7.5 hour shift would show a capacity of 22.5 hours per calendar day shift.
In E9 I have resources under resource groups and I run this utility "Generate Shop Capacity Process" but my shop load report does not update the resource group capacities.
B)- Is there a place to enter the number of resources I have of any one kind like I used to do with machines?
Seems to be correct.
Res Grp contain Resources which are tied to a Calender
# of Res x Hours/day
Are your resources active?
Kind Regards,
Miguel A. Santillan
ERP Administrator
Compass Components, Inc.
510-661-6666 Office
510-656-0603 Fax
msantillan@...<mailto:msantillan@...>
www.ccicms.com<http://www.ccicms.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of greg_clauser
Sent: Tuesday, January 31, 2012 12:39 PM
Charlie Smith
(860) 620-9553
Fax: (847) 374-3620
2W Tech on Facebook
Of greg_clauser
