Shop Schedule Blank Title 73291
Has anyone created or modified the shop load report to show remaining
hours loaded (actual less estimated)?
Regards,
Andrew Best
Kice Industries, Inc.
P(316)744-7151
F(316)295-2412
Of Daniel Laidig
Sent: Thursday, January 22, 2009 9:03 AM
Subject: [Vantage] BPM Force QuoteNum
In quote entry, you can create new quotes with numbers under the
starting
number sequence. I am trying to write a BPM that uses GetNewQuoteHed and
forces in a number besides 0 when I click new quote. When using post
process and the standard action "Set the specified row to the specified
value" it works just fine. I am trying to write a 4GL statement that
does
this but it refuses to work. I didn't know if any of you had some tricks
up
your sleeve to get this to work. Thanks,
Daniel
In quote entry, you can create new quotes with numbers under the starting
value" it works just fine. I am trying to write a 4GL statement that does
this but it refuses to work. I didn't know if any of you had some tricks up
Daniel
