Lynn
They are calculated fields that use palin old available table.field data to produce info that is pertinent to our process management.
Just hit the Calc but when you have either of them highlighted & you'll see the Progress code producing their output values for each record.
Rob
Rob
--- On Thu, 12/18/08, Lynn <lynn.khalife@...> wrote:
Subject: [Vantage] Re: Shop Schedule for 8.03.405A
Date: Thursday, December 18, 2008, 10:45 AM
Dear Rob:
I cannot figure out where the data is coming from for those BAQ
columns named HOTHrs and HrsRmng.
Those names don't appear in the tablename.fieldname list of available
columns.
Lynn
--- In vantage@yahoogroups .com, "Lynn" <lynn.khalife@ ...> wrote:
> Success!
> I forced the Import Dashboard Definition to look for all files
> instead of *.dbd files. Upon selecting the .xml, I got an error
that
> the BAQ did not exist.
> So, I exited and opened the .xml in Microsoft Word and replaced the
> prefix on the BAQ name with the prefix for my company. I resaved
the
> xml file.
> Then my Import Dashboard Definition was successful.
> Thanks a lot!
> Lynn
> --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ >
> wrote:
> > You have to import the dashboard from the xml I uploaded. It'll
> then save as a dbd.
> > Â
> > Let me know if you still have troubles Lynn. Glad someone can
make
> use of it.
> > Â
> > Rob
> > --- On Wed, 12/17/08, Lynn <lynn.khalife@ > wrote:
> > From: Lynn <lynn.khalife@ >
> > To: vantage@yahoogroups .com
> > Date: Wednesday, December 17, 2008, 3:07 PM
> > Dear Rob:
> > I downloaded the 3 files that you posted for this dashboard. I
> > successfully imported the BAQ named VPI96470-MSResSchBr d.xml. I
> > tested it and it returns a dataset with no errors.
> > However, I cannot import the dashboard. Vantage is looking for
> > a .dbd file.
> > When I downloaded the file named MSResSchBrd. dbd, it actually
> saved
> > to my harddrive as MSResSchBrd. xml with the wrong file extension.
> > Am I doing something wrong?
> > Lynn
<robertb_versa@ ...>
> > wrote:
> > > Andrew,
> > > A few months ago I uploaded a dashboard that could probably be
> > easily tweaked to suit your needs (or made into a BAQreport).
It's
> > barebones simple but it works.
> > > Some of the BAQ table.columns may not be pertinent to your
> process
> > but you can add or remove as needed and then reset your sorts as
> > desired.
> > > A nightly BAQ export of the underlying BAQ actually has
replaced
> > our dispatch. (The csv export output acts as the datasource for a
> > task scheduled excel report with an Auto_Open vbscript to auto
> > refresh, print and save for online use).
> > > Rob
> > > --- On Wed, 11/26/08, Andrew Best <abest@> wrote:
> > > From: Andrew Best <abest@>
> > > Subject: [Vantage] Shop Schedule for 8.03.405A
> > > Date: Wednesday, November 26, 2008, 10:10 AM
> > > Does anyone have a shop schedule that will show operations by
> > Resource
> > > group by start date of the operation instead of by operation.
We
> > have
> > > 50+ welders and it is difficult for the welding supervisor to
use
> > the
> > > Progress report to see what they need to be expediting because
of
> > how
> > > the report breaks it down by operation.
> > > Regards,
> > > Andrew Best
