Shopfloor PCs Blank Title 94922
Great, thank you David!
--- In vantage@yahoogroups.com, "David G" <dave.glazewski@...> wrote:
> No moving parts on it so dust and dirt aren't an issue there. They claim that heat isn't an issue and I haven't had any problems with L230 in our shop and I have 9 of them running 24/7
> --- In vantage@yahoogroups.com, "Mike" <mikeyto_96@> wrote:
> > David, is the L300 susceptible to overheating from dirt/dust clogs that a regular PC would be in the same type environment?
> > --- In vantage@yahoogroups.com, "David G" <dave.glazewski@> wrote:
> > > Check out the L300 Series from NComputing. We use them for our Data collectors (MES) in a machine shop environment. I have the host pc in the server room and then 4 l230's (L300 wasn't out when I did this project), and haven't had an issue with them in over 2 years. http://www.ncomputing.com/products-lseries
> > > --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@> wrote:
> > > > Hi,
> > > > We currently require a new shopfloor PC.
> > > > Currently we use some old Dells which work fine. We dont have any more old ones
> > > > and putting a new singing and dancing machine out on the factory seems an
> > > > overkill.
> > > > Does Epicor client run on Linux?
> > > > Has anyone had any experience using low budget small form factor (low ish spec)
> > > > machines for MES terminals?
> > > > Thanks.
> > > > [Non-text portions of this message have been removed]
Hi,
overkill.
Thanks.
The Epicor client does not run directly on Linux, but you can fake it.
We have a handful of Linux clients on the floor, connecting to a Windows
terminal server that can run Vantage (ver 6.1). The system
automatically boots into the remote desktop client with a profile that
does an automatic login and program start on the server, and displays
the Vantage window only (a customized, limited use MES). But the
majority of our machines (office & most MES) are Windows.
Brian.
Of Chris Thompson
Sent: Tuesday, October 26, 2010 9:39 AM
Subject: [Vantage] Shopfloor PCs
Hi,
old ones
an
overkill.
ish spec)
Thanks.
We buy off-lease Dell systems from Systime for around $250 for the
computer itself. If you're in a Citrix environment a
minimally-configured system is fine. If you're running the client
locally, you'll want 2GB RAM.
-bws
Of Brian Roberts
Sent: Tuesday, October 26, 2010 2:05 PM
Subject: RE: [Vantage] Shopfloor PCs
Brian.
Of Chris Thompson
Hi,
old ones
an
overkill.
ish spec)
Thanks.
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi,
> overkill.
> Thanks.
> > Hi,
> > overkill.
> > Thanks.
> > > Hi,
> > > overkill.
> > > Thanks.
