Julie,
I changed the date to Jan 1st 2009 through Dec. 31st 2009, same result; I
checked Plant Performance that has the start date 07/01/06 and end date
08/31/06, when I run the Refresh, it goes thru Records selected and that is
all.
If I double click on the report I get a message "This Data Set is empty. Do
you want to refresh this Data Set?"
If I answer Yes it scans thru the Record Selected again; if I answer No it
will show the Window Performance screen but all grayed out, also shows the
start date, the end date but nothing I the Refreshed box.
Jerry
all.
Jerry
