Simple Bam Problem
If you're talking about Eric Butler at Epicor, then yes, he is awesome. He helped me a lot with BPMs too and he is very good at what he does.
--- In vantage@yahoogroups.com, "Trzaska, Mark" <mtrzaska@...> wrote:
> Thanks For all the help. But I have recently was introduced to BPM's. I sound like a newbie but this thing is awesome. Thanx to Eric at epicor for showing me the light. ICON_X
Hello all,
I am attempting to create a BAM when certain Checkoff fields in DMR header are checked of. Once a checkoff is checked (for example checkoff1) i want to send an e-mail to certain individuals.
Easy enough, I created the bam selecting DMRHEAD and the field checkoff1. Set-up rule saying when checkoff1 = yes. And setup the action to alert sending verbage to recipients.
Needless to say when i checkoff the box. nothing happens. I know global alerts work becuase we are receiving them on a regular basis. Is there something i missed?
Is it something in the customization that is not set-up right. Epibinding field shows dmrhead,checkoff1. Datasource shows DMRhead and datafield is set to checkoff1. Do i have to create something in the wizards?
At a loss.
I am trying to simply bring a ud from ShipHead.Character09
Over to BOLHead.Character09 using BOLSlip
FKV from BOLSlip to ShipHead
And it doesn't work?
And can't figure out What am I missing?
Sent from my Verizon Wireless BlackBerry
Date: Tue, 18 May 2010 14:16:18
To: <vantage@yahoogroups.com>
Subject: [Vantage] Simple Bam Problem
Hello all,
At a loss.
I know this sounds like a broken record response, but you may want to
verify with support that the table and field are compatible with BAM's.
It may be a shock to learn that there are quite a few tables and fields
in Vantage that are not. There is also no comprehensive list of
compatible tables either (I know another blatant shock) that was the
first thing I asked when I ran into a similar situation. I am not
saying that is what your problem is, but it is one realistic
possibility.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of jesh1975
Sent: Tuesday, May 18, 2010 9:16 AM
Hello all,
something i missed?
wizards?
At a loss.
Have you tried without the rule in place?
> possibility.
> Rob Bucek
> FAX: (715)284-4084
> Of jesh1975
> Hello all,
> something i missed?
> wizards?
> At a loss.
Tried with no rule. It's a no-go. Lol whats annoying is I can do certain things that appear to be more complicated, but when I try what I think is easy it fails. Murphy's Law?
Thanx for the help all
 I do know that for all of the 'BAM Alerts' that we set up ,  I've written Progress .p procedures
that check the conditions and send/not send emails (in your case,: If checkoff1 = True then...). We are on an older version and I don't think we have 'rules' available so we have to go this way, works good.
--- On Tue, 5/18/10, bw2868bond <bwalker@...> wrote:
Subject: [Vantage] Re: Simple Bam Problem
Date: Tuesday, May 18, 2010, 3:08 PM
Â
> possibility.
> Rob Bucek
3111
> FAX: (715)284-4084
> Of jesh1975
> Hello all,
> something i missed?
and
> wizards?
> At a loss.
I had the same problem when attempting to set up BAM email alerts on the DMR tables. Other tables worked fine so I know it was all configured correctly. I had to assume those tables did not work and so I used SQL triggers to send my emails instead of using the BAM.
--- In vantage@yahoogroups.com, "jesh1975" <jesh1975@...> wrote:
> Hello all,
> At a loss.
