"Simple" BAM Question In 8.03.305K
Thanks for the tip, Charles.
Ahmet
--- In vantage@yahoogroups.com, Charles Carden <ccarden@...> wrote:
> BPM came into existence with Version 8.03xxx. It was free but you
did have to enter the license code. I am not sure if it required a
purchased license after that time because we moved from 8.00 to 8.03
and received the license codes then. The server portion of BPM is
required if you will be executing code outside of Vantage through
Messaging Queues. The basic and simple processes of BPM will work
without the server being installed. If the server is installed then
the BPM actions process must be scheduled within Vantage for
communication with the BPM server. I found absolutely no
documentation on how to install the server or how to set up the
message queuing process. I think this is another one of those
things that Epicor wants you to pay a consultant to come out and
setup for you. Best of Luck.
Behalf Of vantage
> Sent: Wednesday, August 06, 2008 8:51 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: "Simple" BAM Question In 8.03.305K
> BPM does not need to be purchased when you get to version 8.03.400.
If you
> did not received the new license code for it when the sent you the
disks you
> just need to talk to your CAM to get them sent to you.
> Steve
> -----Original Message-----
> From: nmtaylor1969 [mailto:n.taylor@...<mailto:n.taylor%40kingfield-
electronics.co.uk>]
> Sent: August 06, 2008 7:57 AM
> Subject: [Vantage] Re: "Simple" BAM Question In 8.03.305K
> Hi Ahmet,
> I don't think there is any BPM functionality in Vantage without
> buying the license, but I could be wrong. Epicor actually forgot to
> install our BPM software until recently so I can confirm that we had
> nothing available to us until the license was activated. I guess we
> must have the BPM server installed as part of the BPM install.
> Sorry I can't be more helpful...
> Thanks,
> Nick
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
Ahmet
> Erispaha <ahmeterispaha@>
> wrote:
> > Hi Nick,
> > It looks like I misinterpreted what I read in the Epicor Tools
User
> Guide. If some subset of the BPM functionality came with the base
> Vantage system, I would have used it to demonstrate its capability
to
> my boss in order to justify purchasing the actual license, but it
> sounds like that won't be possible.
> > I'm curious, do you have BPM Server installed -- according to
> Epicor this is an optional BPM component?
> > Thanks,
> > Ahmet Erispaha
> > --- On Wed, 8/6/08, nmtaylor1969 <n.taylor@> wrote:
> > From: nmtaylor1969 <n.taylor@>
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > Date: Wednesday, August 6, 2008, 1:42 AM
> > Hi Ahmet,
> > I am also new to writing BPM's, but I don't quite follow your
> > question... As far as our licensing is concerned you buy the BPM
> > license ( "Epicor" and "free" are never words I usually put
> > together! ), and that's the end of it. You then have all the tools
> > you need.
> > I think you are referring to the "BPM Advanced User" setting
within
> > your user security settings. Its located within the user
> maintenance
> > form. Once checked, you can then carry out advanced BPM actions.
> > I hope this helps...
> > Thanks,
> > Nick
> > --- In vantage@yahoogroups .com, Ahmet Erispaha
> <ahmeterispaha@ ...>
> > wrote:
> > > I'm new to the BPM game and have a question for the more
> > experienced users of this feature.
> > > According to the Epicor Tools User Guide, there is a base level
> > which is bundled free with the software and an advanced level
which
> > costs extra. Which level are you folks using?
> > > Thanks,
> > > Ahmet Erispaha
> > > --- On Mon, 8/4/08, Stephen Edginton <stephene@ .> wrote:
> > > From: Stephen Edginton <stephene@ .>
> > > To: vantage@yahoogroups .com
> > > Date: Monday, August 4, 2008, 11:38 AM
> > > Nick,
> > > If this is your first, ensure you start the BPM action process,
> > > Else you will be wondering where your email is and why it hasn't
> > been
> > > sent.
> > > Regards,
> > > Stephen
> > > From: vantage@yahoogroups .com [mailto:vantage@
yahoogroups .com]
> On
> > Behalf
> > > Of nmtaylor1969
> > > Sent: 04 August 2008 16:35
> > > Thanks Stephen / Daniel, you both had the same idea...!
> > > I have not written a BPM yet, so I might as well make this my
> > > first... :o)
> > > I will shout for help if ( when ) I get stuck!
> > > Thanks,
> > > Nick
> > > --- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> > com> ,
> > > "Stephen Edginton" <stephene@ .>
> > > wrote:
> > > > Hi Nick,
> > > > Why not just use a BPM?
> > > > Use RowMod to catch the new entry RowMod = "A"
> > > > Create an Action to send the email.
> > > > You should be able to get what you need without any
> > > > code.
> > > > Regards,
> > > > Stephen
> > > > From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> > com>
> > > [mailto:vantage@ yahoogroups .com <mailto:vantage%
40yahoogroups.
> > com> ] On
> > > Behalf
> > > > Of nmtaylor1969
> > > > Sent: 04 August 2008 16:05
> > > > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> com>
> > > > Subject: [Vantage] "Simple" BAM Question In 8.03.305K
> > > > I know the answer to this is going to be really simple, but
can
> > > someone
> > > > tell me how I trigger an email notification when I add a new
> > vendor
> > > to
> > > > the database please...?
> > > > I have different departments that manage specific elements of
> the
> > > > vendor data ( let's say accounts and purchasing for a start ),
> > and
> > > when
> > > > one enters a new vendor I would like to let the others know
> > > > automatically. ..
> > > > I am assuming it must be a Business Activity Management type
> > > process,
> > > > but I can't see how to generate an email only when a record is
> > > added...?
> > > > Any help would be most welcome...
> > > > Many thanks,
> > > > Nick
> > > > [Non-text portions of this message have been removed]
> DISCLAIMER:
> This e-mail, including attachments, may include confidential and/or
proprietary information, and may be used only by the person or entity
to which it is addressed. If the reader of this e-mail is not the
intended recipient or his or her authorized agent, the reader is
hereby notified that any dissemination, distribution or copying of
this e-mail is prohibited. If you have received this e-mail in error,
please notify the sender by replying to this message and delete this
e-mail immediately.
I know the answer to this is going to be really simple, but can someone
tell me how I trigger an email notification when I add a new vendor to
I have different departments that manage specific elements of the
vendor data ( let's say accounts and purchasing for a start ), and when
automatically...
I am assuming it must be a Business Activity Management type process,
but I can't see how to generate an email only when a record is added...?
Many thanks,
Nick
I would use BPM and RowMod = "A" in your condition.
Daniel
_____
nmtaylor1969
Sent: Monday, August 04, 2008 11:05 AM
automatically...
Many thanks,
Nick
Hi Nick,
code.
Regards,
Stephen
Of nmtaylor1969
automatically...
Many thanks,
Nick
first... :o)
Nick
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> Hi Nick,
> code.
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
someone
to
when
> automatically...
process,
added...?
> Many thanks,
> Nick
Nick,
Else you will be wondering where your email is and why it hasn't been
sent.
Regards,
Stephen
Of nmtaylor1969
first... :o)
Nick
wrote:
> Hi Nick,
> code.
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
someone
to
when
> automatically...
process,
added...?
> Many thanks,
> Nick
Nice one, thanks Stephen...
I have the Epicor tools user guide which seems pretty comprehensive,
so we will see how we get on.
Thanks again,
Nick
wrote:
> Nick,
been
> sent.
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
> first... :o)
> Thanks,
> Nick
> "Stephen Edginton" <stephene@>
> wrote:
> > Hi Nick,
> > code.
> > Regards,
> > Stephen
> Behalf
> > Of nmtaylor1969
> someone
vendor
> to
and
> when
> > automatically...
> process,
> added...?
> > Many thanks,
> > Nick
> first... :o)
Adding to Stephen and Daniel's suggestion, there's more you can do with BPM
than just send an email. If you have the Task Management Modules (used in
CRM, Help Desk, CRM) then you can ALSO put a Task in their Task List. The
nice thing about this is that when someone is out then the Task can be
visible without giving someone else access to a mailbox, etc. It also won't
get "lost" in a sea of other messages and remains there until complete. You
can also tag the vendor with a "hold" which can show up on BAQs and reports
on items waiting for action. There's a lot more to do than with BAM.
Mark W.
You mean they can get addictive Mark...!?
Thats sounds very good, I am just reading the book at the moment, so
when I give up with that I will come back to you and ask you how I do
it...! ;o)
We have found the task manager in the CRM module to be a bit clunky,
so this will be a way of putting it to good use. We certainly have
issues at the moment with notifications being sent out via email and
getting lost in the noise...
Thanks for the advice,
Nick
> > first... :o)
with BPM
(used in
List. The
be
also won't
complete. You
reports
> Mark W.
I'm new to the BPM game and have a question for the more experienced users of this feature.Â
Â
According to the Epicor Tools User Guide, there is a base level which is bundled free with the software and an advanced level which costs extra. Which level are you folks using?
Â
Â
Ahmet Erispaha
Nick,
sent.
Regards,
Stephen
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of nmtaylor1969
first... :o)
Nick
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
"Stephen Edginton" <stephene@.. .>
wrote:
> Hi Nick,
> code.
> Regards,
> Stephen
> From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
> Of nmtaylor1969
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
someone
to
when
> automatically. ..
process,
added...?
> Many thanks,
> Nick
Hi Ahmet,
you need.
I think you are referring to the "BPM Advanced User" setting within
your user security settings. Its located within the user maintenance
Nick
--- In vantage@yahoogroups.com, Ahmet Erispaha <ahmeterispaha@...>
> Â
> Â
> Thanks,
> Â
> Ahmet Erispaha
> From: Stephen Edginton <stephene@...>
> Nick,
been
> sent.
> Regards,
> Stephen
Behalf
> Of nmtaylor1969
> first... :o)
> Thanks,
> Nick
com> ,
> wrote:
> > Hi Nick,
> > code.
> > Regards,
> > Stephen
com>
com> ] On
> Behalf
> > Of nmtaylor1969
> someone
vendor
> to
and
> when
> > automatically. ..
> process,
> added...?
> > Many thanks,
> > Nick
Hi Nick,
Â
It looks like I misinterpreted what I read in the Epicor Tools User Guide. If some subset of the BPM functionality came with the base Vantage system, I would have used it to demonstrate its capability to my boss in order to justify purchasing the actual license, but it sounds like that won't be possible.Â
Â
I'm curious, do you have BPM Server installed -- according to Epicor this is an optional BPM component?
Â
Â
Ahmet ErispahaÂ
Hi Ahmet,
you need.
Nick
--- In vantage@yahoogroups .com, Ahmet Erispaha <ahmeterispaha@ ...>
> Â
> Â
> Thanks,
> Â
> Ahmet Erispaha
> --- On Mon, 8/4/08, Stephen Edginton <stephene@.. .> wrote:
> From: Stephen Edginton <stephene@.. .>
> Nick,
been
> sent.
> Regards,
> Stephen
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
> Of nmtaylor1969
> first... :o)
> Thanks,
> Nick
com> ,
> wrote:
> > Hi Nick,
> > code.
> > Regards,
> > Stephen
com>
> [mailto:vantage@ yahoogroups .com <mailto:vantage% 40yahoogroups.
com> ] On
> Behalf
> > Of nmtaylor1969
> someone
vendor
> to
and
> when
> > automatically. ..
> process,
> added...?
> > Many thanks,
> > Nick
Hi Ahmet,
Nick
wrote:
> Hi Nick,
> Â
> Â
> Â
> Thanks,
> Â
> Ahmet ErispahaÂ
> From: nmtaylor1969 <n.taylor@...>
> Hi Ahmet,
> you need.
maintenance
> Thanks,
> Nick
> > Â
> > Â
> > Thanks,
> > Â
> > Ahmet Erispaha
> > Nick,
> been
> > sent.
> > Regards,
> > Stephen
On
> Behalf
> > Of nmtaylor1969
> > first... :o)
> > Thanks,
> > Nick
> com> ,
> > wrote:
> > > Hi Nick,
> > > code.
> > > Regards,
> > > Stephen
> com>
> com> ] On
> > Behalf
> > > Of nmtaylor1969
com>
> > someone
> vendor
> > to
the
> and
> > when
> > > automatically. ..
> > process,
> > added...?
> > > Many thanks,
> > > Nick
Thanks, Nick.
That was helpful.
Ahmet
Date: Wednesday, August 6, 2008, 8:56 AM
Hi Ahmet,
Nick
wrote:
> Hi Nick,
> Â
> Â
> Â
> Thanks,
> Â
> Ahmet ErispahaÂ
> --- On Wed, 8/6/08, nmtaylor1969 <n.taylor@.. .> wrote:
> From: nmtaylor1969 <n.taylor@.. .>
> Hi Ahmet,
> you need.
maintenance
> Thanks,
> Nick
> > Â
> > Â
> > Thanks,
> > Â
> > Ahmet Erispaha
> > Nick,
> been
> > sent.
> > Regards,
> > Stephen
On
> Behalf
> > Of nmtaylor1969
> > first... :o)
> > Thanks,
> > Nick
> com> ,
> > wrote:
> > > Hi Nick,
> > > code.
> > > Regards,
> > > Stephen
> com>
> com> ] On
> > Behalf
> > > Of nmtaylor1969
com>
> > someone
> vendor
> > to
the
> and
> > when
> > > automatically. ..
> > process,
> > added...?
> > > Many thanks,
> > > Nick
BPM does not need to be purchased when you get to version 8.03.400. If you
did not received the new license code for it when the sent you the disks you
Steve
Hi Ahmet,
Nick
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, Ahmet
wrote:
> Hi Nick,
> Thanks,
> Ahmet Erispaha
> Hi Ahmet,
> you need.
maintenance
> Thanks,
> Nick
> > Thanks,
> > Ahmet Erispaha
> > Nick,
> been
> > sent.
> > Regards,
> > Stephen
On
> Behalf
> > Of nmtaylor1969
> > first... :o)
> > Thanks,
> > Nick
> com> ,
> > wrote:
> > > Hi Nick,
> > > code.
> > > Regards,
> > > Stephen
> com>
> com> ] On
> > Behalf
> > > Of nmtaylor1969
com>
> > someone
> vendor
> > to
the
> and
> > when
> > > automatically. ..
> > process,
> > added...?
> > > Many thanks,
> > > Nick
Thanks for clearing that up, Steve! I'll contact our CAM.
Â
Regards,
Â
Ahmet Erispaha
Date: Wednesday, August 6, 2008, 9:51 AM
Steve
From: nmtaylor1969 [mailto:n.taylor@kingfield- electronics. co.uk]
Hi Ahmet,
Nick
--- In vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com, Ahmet
wrote:
> Hi Nick,
> Thanks,
> Ahmet Erispaha
> To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
> Hi Ahmet,
> you need.
maintenance
> Thanks,
> Nick
> > Thanks,
> > Ahmet Erispaha
> > Nick,
> been
> > sent.
> > Regards,
> > Stephen
On
> Behalf
> > Of nmtaylor1969
> > first... :o)
> > Thanks,
> > Nick
> com> ,
> > wrote:
> > > Hi Nick,
> > > code.
> > > Regards,
> > > Stephen
> com>
> com> ] On
> > Behalf
> > > Of nmtaylor1969
com>
> > someone
> vendor
> > to
the
> and
> > when
> > > automatically. ..
> > process,
> > added...?
> > > Many thanks,
> > > Nick
BPM came into existence with Version 8.03xxx. It was free but you did have to enter the license code. I am not sure if it required a purchased license after that time because we moved from 8.00 to 8.03 and received the license codes then. The server portion of BPM is required if you will be executing code outside of Vantage through Messaging Queues. The basic and simple processes of BPM will work without the server being installed. If the server is installed then the BPM actions process must be scheduled within Vantage for communication with the BPM server. I found absolutely no documentation on how to install the server or how to set up the message queuing process. I think this is another one of those things that Epicor wants you to pay a consultant to come out and setup for you. Best of Luck.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of vantage
Steve
From: nmtaylor1969 [mailto:n.taylor@...<mailto:n.taylor%40kingfield-electronics.co.uk>]
Hi Ahmet,
Nick
wrote:
> Hi Nick,
> Thanks,
> Ahmet Erispaha
> Hi Ahmet,
> you need.
maintenance
> Thanks,
> Nick
> > Thanks,
> > Ahmet Erispaha
> > Nick,
> been
> > sent.
> > Regards,
> > Stephen
On
> Behalf
> > Of nmtaylor1969
> > first... :o)
> > Thanks,
> > Nick
> com> ,
> > wrote:
> > > Hi Nick,
> > > code.
> > > Regards,
> > > Stephen
> com>
> com> ] On
> > Behalf
> > > Of nmtaylor1969
com>
> > someone
> vendor
> > to
the
> and
> > when
> > > automatically. ..
> > process,
> > added...?
> > > Many thanks,
> > > Nick
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
They also forgot to send the licence codes for BPM to us until I queried
why I couldn't find it after going on the training course! So don't be
afraid to ask.
kind regards
Debbie Stokes
Vantage Administrator
Hilo-PSS Group
01793 647136
This email is intended for the addressee only and may contain information that is privileged and confidential. If you are not the intended recipient, you must not copy, distribute or take any
action in reliance on it. If this email has been sent to you in error, please notify us immediately by telephone.
This has been transmitted by -
Hilo-PSS Group
Murdock Road
Dorcan Industrial Estate
Swindon
SN3 5HY
Company Registration No: 01028915.
The views within this email are those of the author and not
necessarily those of Planned Storage Systems Ltd.
** This email has been scanned for viruses, vandals and malicious content **
