I have the guide, it doesn't show how to handle error messages.
On Jun 1, 2012, at 5:41 PM, "Len Hartka" <len.hartka@...> wrote:
> Good Day Patrick:
> There is the "ICE tools User guide" ( MUST be 9.05) which can
> either be bought as a book ( 50 maybe $100) or down loaded from EpicWeb.
> Call helpline for help.
> Len
> Of Winter, Patrick
> Sent: Friday, June 01, 2012 6:29 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Simple BAQ - Calculated Field - Error Message
> Yes logical
> On Jun 1, 2012, at 5:03 PM, "Len Hartka" <len.hartka@...
> <mailto:len.hartka%40sunautomation.com> > wrote:
> > Good Day:
> > I pasted your string and it worked.
> > If Menu.OptionSubType = 'R' then yes Else no
> > Do you have the "Data Type" as Logical in the upper screen? If
> > "number" it will fail.
> > len.hartka@... <mailto:len.hartka%40sunautomation.com>
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of Ted Koch
> > Sent: Friday, June 01, 2012 5:35 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > If you save the calculated field and test the BAQ it runs.
> > P.S. - If you take Menu.MenuType out of the displayed columns and run
> > check syntax it says syntax ok.
> > From: "Winter, Patrick" <pjw@...
> <mailto:pjw%40specialtyscrew.com>
> > <mailto:pjw%40specialtyscrew.com> >
> > Sent: Friday, June 1, 2012 5:25 PM
> > Subject: [Vantage] Simple BAQ - Calculated Field - Error Message
> > All,
> > Simple BAQ, List the reports on the Menu Structure.
> > Menu Table, List Several Fields, All is well.
> > Testing a calculated field.
> > MyTest, Logical yes/no
> > In the Editor I Type:
> > CHECK SYNTAX
> > Error:
> > Field formant doesn't coincide with database schema for fields:
> > Menu.MenuType current format: X(20), expected x(10)
> > I'm sure to see many more error messages as I plan to hammer BAQs,
> Where
> > does one go to resolve or find more information on such error
> messages?
> > Patrick Winter
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > This e-mail and any attachments may contain proprietary and/or
> confidential information. If you are not the intended recipient, please
> notify the sender immediately by reply e-mail or at 410-472-2900 and
> then delete the message without using, disseminating, or copying this
> message or any portion thereof. With e-mail communications you are urged
> to protect against viruses.
> This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
