since the update to 2026.100 we can use our reports in which we use images for our header and footer. When trying to print a report we get the following error message, see below. How to solve this?
Program Ice.Services.Lib.RunTask when executing task 872038 raised an unexpected exception with the following message: RunTask:
System.InvalidCastException: Failed to convert parameter value from a Byte to a Int64.
—> System.InvalidCastException: Object must implement IConvertible.
at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
at Microsoft.Data.SqlClient.SqlParameter.CoerceValue(Object value, MetaType destinationType, Boolean& coercedToDataFeed, Boolean& typeChanged, Boolean allowStreaming)
— End of inner exception stack trace —
at Microsoft.Data.SqlClient.SqlParameter.GetCoercedValue()
at Microsoft.Data.SqlClient.SqlParameter.Validate(Int32 index, Boolean isCommandProc)
at Microsoft.Data.SqlClient.SqlCommand.BuildParamList(TdsParser parser, SqlParameterCollection parameters, Boolean includeReturnValue)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean isAsync, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry, String method) at Microsoft.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Ice.Core.RptBase.DatabaseReportDataStorage.WriteRow(IDataSource dataSource, IRow row) in C:\_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\RptBase\DatabaseReportDataStorage.cs:line 114 at Ice.Core.RptBase.ReportImagesDataBuilder.WriteRowToAllDataStorages(IDataSource dataSource, IEnumerable1 reportDataStorages, DataSourceRow row) in C:_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\RptBase\ReportImagesDataBuilder.cs:line 69
at Ice.Core.RptBase.ReportImagesDataBuilder.BuildData(IDataSource dataSource, ReportStyleImageTable imageTable, IEnumerable1 reportDataStorages) in C:\_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\RptBase\ReportImagesDataBuilder.cs:line 20 at Ice.Core.RptBase.ReportDataBuilderBase.WriteReportImagesData() in C:\_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDataBuilderBase.cs:line 282 at Ice.Core.RptBase.ReportDataBuilderBase.XSDClose() in C:\_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDataBuilderBase.cs:line 375 at Ice.Core.RptTaskBase1.XSDClose() in C:_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 369
at Erp.Internal.PM.POForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_releases\ERP\ERP12.2.100.0\Source\Server\Internal\PM\POForm\POForm.cs:line 294
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:_releases\ICE\ICE5.2.100.3\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
at Ice.Hosting.TaskCaller.StartProcess(IceDataContext dataContext, Type myType, Operation operation) in C:_releases\ICE\ICE5.2.100.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 133
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext dataContext) in C:_releases\ICE\ICE5.2.100.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 112
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_releases\ICE\ICE5.2.100.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 62
at Ice.Hosting.TaskCaller.ExecuteTask(IceDataContext dataContext, Boolean suppressTransaction) in C:_releases\ICE\ICE5.2.100.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 42
at Ice.Services.Lib.RunTaskSvc.<>c__DisplayClass19_2.b__1() in C:_releases\ICE\ICE5.2.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 352
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_releases\ICE\ICE5.2.100.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 57
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_releases\ICE\ICE5.2.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 349
