Site Forecast no driving demand to site producing the part
I have a part that is mfg at one site but the forecast is loaded and shipped from another site. The Site we ship from the part is type transfer and transfer plant the mfg plant.
When you look in time phase you see all the forecast but when you look at the mfg site there is no unfirmed jobs being created for the demand from the other site.
I can not seem to see what is causing this from not happening. Does anyone have this issue?
Hi Jeanne,
I just tested it on a part and I’m getting the results as expected. Here’s my example, perhaps it can help you.
Nancy
Nancy,
What you sent is what I would of expected to happen but it is not for us. Now to find the cause. If you don’t mind I will send you some screen shots of our data and maybe a second set of eyes will catch where the setup is wrong.
I appreciate any help you can give me.
Jeanne
Nancy,
Attached is the setup for one of the parts that is not working. There seems to be a consistent issues with all our forecasted parts that are shipped from a different site warehouse. I am hoping something pops up that is different from your setup.
Jeanne
Part 12815301 mrp issues.docx (757 KB)
Hi Jeanne,
I have a couple of ideas to try that I think might help. First, I don’t see any transfer order prefix setup. IDK if it’s necessary, but we have them. See below for our setup. You are not getting transfer order suggestion at all. The transfer order suggestion on the receiving plant will create the unfirm job on the sending/mfg (in your case) plant. I do not think that your receiving (i.e., transfer) plants need to be setup as transfer plant themselves. It doesn’t seem like it should have to, if you never want to transfer FROM it.
Finally, days of supply on part plant tab for the plant. We use a minimum of 60 on ours and sometimes use 365 for our long lead parts. I have seen unexpected behavior from very short days of supply. After testing for prefix above, I’d next try inputting 30 or 60 DOS on all of the sites, or zeroing them all. We do not use planning time fence nor schedule deltas… not sure the effect there.
Nancy
Great let me make some changes and see what happens!
Hi Nancy,
I ran into an odd issue. I am unable to give different transfer Order Prefix to each site. What ever I put in the first one listed is defaulting into the others and if I change it changes all. I assume you didn’t have that issues?
I was attempting to have AM = Amana BR=Brad, etc
Hi Jeanne,
Huh… it does seem turned around.
Reviewing mine per below (site config + a dashboard of open transfer lines), while it states it is in the transfer “to” sites 20 and 30 data under Pennsylvania site it really seems to dictate how the system calls transfers TO this site, i.e., TO Pennsylvania. This is making me think that you will need to setup transfer definitions on the sites that you have no intention of transferring from but do intend to transfer to.
Nancy
Nancy are you on version 10.1.600?
If So I love your dashboard, would you be willing to share it with me so I dont have to reinvent the wheel? I would love to import it into my test enviroment
Hi Jeanne,
Sure. It’s pretty basic. Here’s the export of the BAQ + DB. I’m not sure if you can import into your version. In case you have any problems here’s screenshot of the query so you can rebuild if needed.
TransferOrderDashboard.dbd (234.7 KB)
Nancy
Great what version are you on?
10.1.600
Great it’s the same version so I should be able to import
Nancy I have another quick question as we are still struggling with this mess. CAn you send me a screen shot of your transfer order suggestion in time phase? I am still having issues not see a job suggestion.
thanks
Jeanne
Hi Jeanne,
Look back up at Post #2 in chain, above. Do these timephase screenshots with the transfer order suggestions help at all?
Nancy
Sorry I didn’t go back that far………this has been a very long process for us in trying to back track.
So if I am reading it right you have a forecast on part 37665c110, so if you went to you forecast screen I would see a forecast for site 10. Do you have it as a general forecast or a Customer specific forecast.
See my example of my forecast
This is what the forecast at my site that needs the parts look like
Now this is what the transfer from site looks like and there are no job suggestions, nothing is carrying across
Hi Jeanne,
I have seen unexpected behavior with days of supply set to 0, and 5 seems really low also. Want to run your MRP with DOS set to 30 or 60days and see what the results are then? Our forecast is not per customer, it’s just to put load on system to order what we expect to use over our lead time.
Nancy
Great I will make that change and also move it to general forecast instead of customer and see what that does. I will let you know……lol
Nancy
Are you creating Transfer orders in your sites first? I was able to see an unfirmed job created for one of my parts but not from the forecast only the Transfer Order that was already in the system.
Nancy here is the forecast window I forgot to send with the part in question
