OK, I found the BAQ for slow moving inventory in the files section. I read the instructions. It says it was written in Vantage 8.03.404. I am on Vista 8.03.409c. I copied the first file and change the company ID to mine. When I tried to import it I got the following messge: The BAR Report Definition Import file (saved name of file) is in the incorrect format and cannot be imported.
I am a Master Scheduler, not an IT person. Can someone please help me decode this message and tell me if I can get this report to work for me?
Georgia
Georgia
--- In vantage@yahoogroups.com, Grace Chandra <grace@...> wrote:
> Lynn,
> I know its been such a long time, but would you mind sending me the BAQ Report as well?
> Thank you so much.
> Grace Chandra
> Controller
> - - - - - - - - - - -Â - - - - - - - - - - -Â - - - - - - - - - - -Â - - - - - - - - - -
> t.  (630) 889-8100 FC Lighting
> f.  (630) 889-8106 3609 Swenson Ave.
> e. grace@... St. Charles, IL 60174
> w.  www.fclighting.com
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Lynn
> Sent: Wednesday, May 06, 2009 10:18 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Slow Moving Inventory Report
> I have a BAQ and BAQ Report which queries all the Part Bins to look for parts in stock, then it finds the last inventory transaction date from the PartTran table.
> It also has links to the CustXPrt, Customer, and Part tables in order to show the Customer name, Customer Part Number and SearchWord.
> The BAQ could easily be used in a dashboard instead of a BAQ CR for even more flexibility. In fact, I was planning on making a dashboard from it.
> If this is what you are looking for, I could send it to you.
> Lynn
