Slow performance
John Hawk wrote:
> You should be able to copy 78 MB of data from the server to the XP station in less than 20 seconds.
I also use file copy times for a rough sanity check on network
throughput, but you're off by a lot there.
78MB should take 8 seconds (at nearly 10MB/sec) on 100Mb. On gigabit
ethernet I get 25 - 30MB/sec which should be about 3 seconds for 78MB.
I'd like to see some improvement on my Gb, but that's what I'm getting
now...
-Wayne
We are running Vantage 8.03.305I with MS SQL 2005 SP2. My server is MS
2003 R2 Enterprise Edition SP2 running on a Dell PowerEdge 2950 with
dual 3.0 GHz Xeon processors and 8.0 GB of ram. My desktops are all MS
Windows XP SP2 with 3.0 GHz Pentium D's and better with at least 1.0 GB
of ram. My network is 1.0 Gbps throughout, servers, switches,
desktops. This system is horribly slow at best. Is anyone else
experiencing poor performance in a similar environment? I have done
everything I can think of including having the server settings
optimized for vantage. All software firewalls have been disabled and
all anti-virus has the vantage client folder excluded. Any insight or
confirmation would be great. Thanks.
Is this a new network? Was it ever fast?
>>> "psfny" <psfny@...> 10/16/2007 3:10 PM >>>
Are you sure you do not have any old hubs that are 10/100, or any ports
that can be switched to 10/100?
If you have a dying port it can bring your network down....this is just
one idea.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of John Hawk
Sent: Tuesday, October 16, 2007 3:12 PM
Subject: Re: [Vantage] slow performance
>>> "psfny" <psfny@... <mailto:psfny%40yahoo.com> > 10/16/2007
3:10 PM >>>
this is an existing network, all other apps run fine. no transfer
issues whatsoever.
is MS
with
all MS
1.0 GB
done
and
or
nope, everything is full gigabit. i checked all the ports on the
switches, i checked each server nic and each desktop nic.
ports
just
> one idea.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of John Hawk
> 3:10 PM >>>
MS
with
MS
1.0 GB
and
or
When you say, "slow performance," what is actually performing slowly?
Launching Vantage? Or switching within menus/screens inside of Vantage?
You could put a traffic-sniffer (WireShark) on the network to see what
might be happening behind the scenes on the network when you launch or
use Vantage, and filter the logs by station-IP and/or port number.
Additionally, there are two useful programs: FileMon and RegMon, that
might help to see what's happening on the client/server when you launch
the program. If you take the data from all three and correlate it by
time/activity, you might get an idea as to where the bottle-neck is.
I've used WireShark (formerly Ethereal) to help me identify SQL database
problems in the past. Result: SQL virus! Would have never found it
without the sniffer showing me excessive traffic to/from the DB
server...
--Ari
Ari Footlik
IT Manager - R. A. Zweig
Of psfny
Sent: Tuesday, October 16, 2007 4:49 PM
Subject: [Vantage] Re: slow performance
ports
just
> one idea.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of John Hawk
> 3:10 PM >>>
MS
with
MS
1.0 GB
and
or
We are running Vista on Progress and one of the major complaints that I get is how slow the application is. From what I am told, it has been a pretty general complaint of the system. Version 8.03.4xx changes the processing from the client to the server and is supposed to be alot quicker. I don't know how differently it runs on SQL but I do know that the speed has been a pretty wide nspread complaint
Sent: Tue 10/16/2007 5:49 PM
Cc:
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Manasa Reddy" <manasa@...> wrote:
ports
just
> one idea.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
> Of John Hawk
> 3:10 PM >>>
MS
with
MS
1.0 GB
and
or
Does your server pass out ip addresses via DHCP and specify the server itself
as the DNS server to use for the XP stations?
What is the DNS for the XP stations? Should be your Windows 2003 server.
Use wireshark like the other person indicated.
Do you see any yellow or error lights on the switches?
Many times the duplex doesn't match.
What brand and model of switches?
I assume they are intelligent.
You can read the logs on most.
If it says minutes, something is wrong.
Are the Workstations and the server on the same segment and VLAN?
Are they really on the same subnet?
Are the pings fine? <3ms?
A traceroute shows 1 hop to the server from the XP ?
If you run perfmon on the server, it isn't saturated on the lan or disks or CPU?
I am testing Vantage 8.03.403b on real hardware.
Dual 2.8 GHz Xeon
4Gb Ram
Windows 2003 Server
Entire db in Ram, I am not impressed at all with the time required to
update a 74 line PO. perception is it is longer than 8.00.811 and is
born out in tracing execution times. Client app run on same server as
Vantage so no network issues involved.
.02
--- In vantage@yahoogroups.com, "Kersten MacLennan" <kmaclennan@...>
> From: psfny [mailto:psfny@...]
> Cc:
the
or any
> ports
down....this is
> just
> > one idea.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> Behalf
> > Of John Hawk
40yahoogroups.com>
> > >>> "psfny" <psfny@ <mailto:psfny%40yahoo.com> > 10/16/2007
> > 3:10 PM >>>
server is
> MS
2950
> with
are all
> MS
least
> 1.0 GB
switches,
else
have done
settings
disabled
> and
insight
> or
