Jay, I can send a non-authenticated out however then it goes through the my
spam filters. I am testing 1st mail server that will allow
non-authenticated incoming with authenticated outgoing relay. It allows you
to setup IP range list for security. I have not been able to find any free
ware that has these same capabilities to use so I think I will end up
purchasing the software for around $69.
Steve
Sent: Wednesday, March 24, 2010 4:04 PM
Subject: [Vantage] Re: SMTP authentication
I'm having this issue as well. Was there any closure to this?
Jay
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Ari
Footlik" <ari@...> wrote:
Behalf
com/serv?s=97359714/grpId=20369/grpspId=1705007181/msg
Steve
Jay
>[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> I assume you are trying to set your SMTP server-name to something like
> "mail.yourdomain.com" Perhaps that is the problem - that server is in
> all likelihood not the public "mail-exchanger" (MX-record) for your
> domain.
> The mail-exchanger for your domain *must* accept non-authenticated
> sessions because that is the only way incoming email from external
> senders could possibly work. If you point your SMTP settings in Vantage
> to the mail-exchanger, that should give you the functionality you need
> without requiring your ISP to do anything.
> Steve - as a test - I sent you a message. Please let me know if you get
> it.
> --Ari
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Behalf
> Of vantage<mailto:vantage%40yahoogroups.com>
> Sent: Thursday, September 18, 2008 10:08 AM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: RE: [Vantage] SMTP authentication
> You are correct on this! I Have tried to get my ISP to give me an open
> connection without authentication but was told that they would not do
> that.(Level 1 support). I will need to try to move up the support to
> possible get this done, but also trying to find if I can get around this
> problem in a different way.
> Steve
> From: Edward F. Fox, Jr. [mailto:efox@...
> <mailto:efox%40maxsonautomatic.com> ]
> Sent: September 18, 2008 9:06 AM
> Subject: RE: [Vantage] SMTP authentication<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007181/msg>
> In our case, our web and email host requires authentication for it's
> smtp
> server. Because of that, it would reject the Vantage emails from Global
> Alerts. That is why we use the smtp server our ISP (different entity)
> provided.
> Steve may be experiencing the same thing.
> Edward F. Fox, Jr., CPA
> Controller
> Maxson Automatic Machinery Company
> Phone 401-596-0162 Fax 401-596-1050
> www.maxsonautomatic.com
> _____
> Behalf Of
> Ari Footlik
> Sent: Thursday, September 18, 2008 9:58 AM
> I may be wrong, but you shouldn't need to authenticate against the
> server if you're going to be sending an email to an address within your
> own domain/organization.
> "Relay" usually means using your server to send a message *from* an
> external domain *to* an external domain. One wouldn't consider it to be
> a "relay" for the server to process/deliver a message intended for a
> recipient it hosted.
> Think of it this way: When your server received this message, the server
> accepted an incoming connection from the Yahoo server. The initial
> communication/setup included a query from your server as to the intended
> recipient. If the domain of the intended recipient's email address is
> one that the server hosts, it allows the communication *without*
> authentication. If it didn't, no incoming messages would be possible;
> an external SMTP server would never be authenticating to your server to
> send you a message.
> In my opinion, it's likely that something else is going on. Perhaps you
> could install WireShark on your Vantage server and monitor the
> communication to/from the SMTP server? You'd be able to see the actual
> messages being exchanged between the machines during session setup.
> --Ari
> Behalf
> Of rmgfelm
> Sent: Thursday, September 18, 2008 8:31 AM
> Subject: [Vantage] SMTP authentication
> I submitted this question a few days ago and did not receive a
> response, so I wanted to send it out again.
> I am currently running on ver 8.03.405A and looking for some
> suggestions. My current e-mail provider requires SMTP authentication
> and also does not allow SMTP relay. Currently Vantage does not support
> SMTP authentication. Does anyone know of a way to get around this
> problem?
> Thanks
> Steve
> <http://geo.yahoo
> <http://geo.yahoo
> <http://geo.yahoo
> <http://geo.yahoo<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007181/msg>
> > >[Non-text portions of this message have been removed]
> Id=68965/stime=1221744685/nc1=3848584/nc2=5370600/nc3=5286675>
