Sniff test: 9.05.700 server
I'm not sure I follow exactly what you're saying. Would I be correct that
you're talking about splitting the DB across multiple arrays/controllers? I
don't really see any reason to do that. I would generally prefer to just
add more disks to the array.
A good controller and an array of 8+ SSD should be able to support most
anyone.
If you're big enough that such a setup still isn't enough iops, I'd look at
the Fusion IO stuff or one of the similar products, there are also SAN
solutions. Bring the IO to the DB not vice versa.
I wouldn't partition the DB unless it's so big that having a monolithic
volume isn't manageable.
On Thu, May 31, 2012 at 8:56 AM, Nancy Dornacker <nancy.dornacker@...
> wrote:
> Would you also setup the database to be mult-volume and spread across
> multiple logical SSD drives?
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
Over the next several months I will be performing an upgrade from Vista 6.10.543 to Vantage 9.05.700. It fairly well goes without saying that my hardware will also be replaced in the process. However my budget is severely limited.
Epicor's minimum requirements for servers seem a little steep for the demands that my company will be placing on them. Currently I am running Vista on a Microsoft Virtual server with a dedicated 2.5 GHz core, 2GB of RAM, and 16 GB of storage. This services 12 full seats and 4 data entry seats. The backup file for my DB currently 1.81GB.
Will a vm comprised of two cores from an Intel Xeon E5620/2.66 GHz, with 16 GB of RAM, and 75GB of storage adequately meet my needs? My gut says yes, but perhaps I need a gut-check.
Thank you for your time.
I'd try to get a little more CPU if you can manage it, 4 cores at least.
Your ram should probably be ok, but again a little more wouldn't hurt,
especially considering how cheap it is.
The most important thing is disk IO. What do you have under it? I'd suggest
a bare minimum of 6 dedicated 15k spindles if you're going with traditional
disks.
It would be far preferable to go with SSDs. The enterprise-class SSDs are
still pretty pricey. That said, you can get away with using consumer level
drives, just keep a couple spares on hand. We've been using them for some
time with no issues. You can get 180gb units for under $200 these days. I'd
get 6 of them. Set 4 into a raid 10. Give the array it's own controller
and allocate the whole thing to the Epicor VM. Keep the other two on hand
as spares. That should give you plenty of room to grow and iops to spare.
If you try to get by with less disks, or share the array with another VM,
expect performance to be pretty dismal.
Turn on network compression for your users. Assuming your network is
running nice and fast, this should leave you with some fairly solid
performance numbers.
> severely limited.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
I was planning on just one raid controller managing 4x 300GB SAS 10K Hot-Swappables in a RAID 10. I figured this would be a fantastic improvement on my RAID 1 of 500GB SATA's.
Have the IO requirements of Epicor increased enough to justify a secondary raid controller dedicated to it? In an extreme scenario I envision 7 people writing to the DB at one time.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
Re: [Vantage] SNIFF TEST: 9.05.700 SERVER
disks.
> severely limited.
You may be able to get away with one controller if you absolutely have to,
assuming it's a decent one and your other loads are small. But if you're
going to spend the money for 300gb SAS drives, just get the SSDs as you
don't need the extra space anyway.
300GB SAS:
-Five drives at $250 each = $1250
180GB SSD:
-Six drives at $200 = $1200
As long as Epicor is the only thing on the array you should get pretty
decent performance.
> disks.
> > severely limited.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
Thank you, John. I appreciate your time and responses.
> 300GB SAS:
> 180GB SSD:
> decent performance.
> > disks.
> > > severely limited.
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
My pleasure. Hope everything goes smoothly with the upgrade.
> to,
> > 300GB SAS:
> > 180GB SSD:
> > decent performance.
> secondary
> people
> least.
> suggest
> traditional
> > > disks.
> are
> level
> some
> days. I'd
> hand
> spare.
> VM,
> Vista
> that my
> > > > severely limited.
> running
> 2GB of
> entry
> with
> says
> > *John Driggers*
> > **:: 904.404.9233*
> > *:: waffqle@...*
> > *:: NO FAXES*
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
