Perhaps that is a lost and forgotten set of UI DLLs. who knows.
Joshua Giese
Chief Technical Officer
920.437.6400 Ext. 337
*Do not follow where the path may lead. Go instead where there is no path
and leave a trail - Harold R. McAlindon*
cooner_55421
Sent: Thursday, January 12, 2012 10:23 AM
Subject: [Vantage] Re: SO Ack batch printing
someday too?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Joshua
Giese" <jgiese@...> wrote:
Behalf Of
Joshua Giese
cooner_55421
>Couldn't they just have thatWouldn't it be nice to see Epicoe add POs and Invoice printing to the menu
>as a menu item right off the bat?
someday too?
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Holy crap man! That is so cool. What the hey! Couldn't they just have that
> as a menu item right off the bat?! Now on to the Crystal Reports.. That's
> still a huge time saver though thank you so much!
> Joshua Giese
Behalf Of
> Joe Rojas<mailto:vantage%40yahoogroups.com>
> Sent: Wednesday, January 11, 2012 8:16 PM
> Subject: RE: [Vantage] SO Ack batch printing
> Hello,
> Yes, you can do this but there is one major warning.
> If you add Epicor.Mfg.UIRpt.SalesOrderAck.dll to the Epicor menu, you
> can call the report UI and be able to search and select the orders that
> you want to batch together.
> The issue is that the sales order acknowledgement report was designed
> with only a single sales order being printed at a time in mind.
> I tried to do a batch acknowledgement print job and discovered this the
> hard way. I found several bugs that I had to fix. For example, the sub
> reports are not linked properly so a lot of data was showing up on all
> order acknowledgements as opposed to just the related data.
> Once you fix the order acknowledgement report, this approach works
> really well.
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On
> Behalf<mailto:vantage%40yahoogroups.com>
> Of Anon
> Sent: Wednesday, January 11, 2012 3:42 PM
> Subject: [Vantage] SO Ack batch printing[Non-text portions of this message have been removed]
> Is there a way to batch print the order acknowledgements? Say I have
> orders 210-415 I want to print all at once as a single spooled job. Any
> way to do this in E9?
