Hi Tim,
We have/had been experiencing the exact same problem you are describing. It
began when we installed 100BaseT hubs on our network and new Dell workstations.
Our cabling was supposed to be Cat5 certified. HOWEVER, after much
troubleshooting and much head scratching, we brought in some cabling guys to
retest and discovered that our cabling (at least some of it) was not Cat5.
After installing CAT5 in the problem areas, the problem went away.
problems intermittently since the upgrade last month. Here is a sample of
the one error we have been getting the most:
'Error reading socket, ret=0, errno=2 (778)', then
'Incomplete write when writing to the server. (735)', then
'mainmenu.w Database vantage not connected (1006)', then
'Unable to run startup procedure mainmenu.w (492)', then the gray Progress
box where you have to hit the space bar.<<<
Mike Lowe
Corporate I.S. Manager
Connor Manufacturing Services
MLowe@...
(909) 273-1282
>>>Wondering if anyone has experienced any type of client disconnect problemssince upgrading to Vantage 4.0. We have been experiencing many of these
Mike Lowe
MLowe@...
(909) 273-1282
