Ok, I don’t know what I did wrong. It has been a while since I have built a solution file. I am moving some dashboards we created to a new menu item. But I can’t seem to figure out how to remove the old with a solution file. I created the solution file of the General Ops menu item after I removed it but but I installed it in my other environment the old menu item is still there. Does it have to be manually deleted?
thanks
I don’t think there is a way to make the solution workbench remove things. It only overwrites things that have the same name. You’ll have to manually remove them. (as far as I know)
thanks, that is what I was afraid of.
@Kimberley If you disabled it and then added it to the solution it would not “delete” it but users hopefully would not see it anymore.
