Solution Workbench - Report Styles
When building and installing solutions through Solution Workbench for Report Styles, does it also upload the .rdl file when installing the solution? Or do we also need to upload the SSRS Report after installing the solution that includes the .rdl file in the solution? I’m trying to eliminate an unnecessary step of uploading the SSRS report if the install already does this step.
The solution will include the main .rdl and .rdl for sub reports as long as you answer yes when it asks you if you want to include the report style. (And answer yes again for the next report and the next report and the next report…)
When you install the solution, does it automatically upload the .rdl file also in the new environment?
Yes, it would so you don’t have to worry about uploading it manually.
