SonicMQ Container tip to pass on
JJ,
I was equally as annoyed when I discovered this requirement for customer connect.
Seems like it really could have been done better than this.
However, you can register the process as a service so that it starts with the server and does not require an open console.
You should just need to do a check in the beginning of the bat that checks for the lock file and deletes it if it exists.
Carey
To: vantage@yahoogroups.comFrom: jj.tarter@...: Mon, 26 Mar 2007 14:07:01 +0000Subject: [Vantage] SonicMQ Container tip to pass on...
For multi-companies: I discovered over the weekend that the SonicMQ Container dialog box must be left open or minimized on the server upon starting. If you 'x' it out after starting, you are turning it right back off. I didn't find the problem until finally viewing the logs where it was showing the session failing. For the longest time, I thought I was doing something wrong in external company setup on Vantage....grrrrrrrrr....
_________________________________________________________________
Live Search Maps � find all the local information you need, right when you need it.
http://maps.live.com/?icid=wlmtag2&FOR M=MGAC01
In addition, you should NEVER use the 'x' to close it either. The proper
method is CTRL M.
Todd
Of JJ
Sent: Monday, March 26, 2007 10:07 AM
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Oh, thanks! I didn't know about that one!
proper
> method is CTRL M.
> Todd
Behalf
> Of JJ
upon
right
privileged
the
any
other
