Source Part Revision is not Approved for Use? Yes it is
I am getting an error that says:
Source Part Revision is not approved for use. Part/Rev:XXXX/YY
Stating the obvious, the revision is, in fact, Approved. What else might cause this behavior? Specifically, I am trying to Get Details on a job from the part’s method.
I will also say I’ve done some DMT work over the past couple weeks to move parts from Site A to Site B. Our configured products are on the list that were moved. This part is a configured part/rev. Where else might I check besides just on the part revision? Any ideas?
Well, the Configurator was the key. I had thought that the configurator was synced with the revision on the part it was defined on but I guess I was wrong. The base part revision was not approved even though the various configured part numbers was approved. Whoops.
I’m surprised it let you run the configurator from Order Entry without the rev approved.
