This isn't operator error because the records have been set up for at
least 8 years (since we started using Vantage). At any rate, support
sent me a fix yesterday so this apparently is a bug. Thanks for all
the replies!!
Sue
the replies!!
Sue
--- In vantage@yahoogroups.com, <lonwiksell@...> wrote:
> It may be an operator error but Vantage should never allow that to
> happen. Birthdate should be edited for correctness. In other words
> birthdate can not be greater than today and probably questioned if
it is
> not today + 16 years. Likewise birthdate should be questioned if
it is
> more than 70 years ago. This is a big problem with Vantage because
many
> dates such as order dates are not properly edited. I have written
> several Access programs that do after the fact edit checking that
should
> be done on data entry.
> Lon
> ROM Corporation
Behalf
> Of pvolkert365
> Sent: Friday, April 11, 2008 3:49 PM
> To: vantage@yahoogroups.com
> Subject: Re: [SPAM] [Vantage] Employee File Birthdate Corruption
> A year ago (8.03.305x) I made the exact same discovery. Some of our
> birthdates had jumped ahead 100 years. I even put a support call
> in. I finally realized that the person entering the data had used
> two digits for the year and it was in there as 2050 instead of
1950.
> Since you rarely look at that field, it was not noticed. But it was
> operator error.
> -Peter
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Calvin Krusen" <ckrusen@> wrote:
> > I Hope not!
> > Isn't the 19 century the 1800's? Just Kidding.
> > But seriously, does Epicor/Progress use pre-Y2K thinking with
their
> DBs?
> > I thought all dates were stored as days from a defined day 'zero'.
> > Could this really be a user interface issue? Meaning that when
> only two
> > digits are entered for the year, the system guesses the century
to
> use.
> > Calvin Krusen
> "Winter, Patrick" <pjw@> wrote:
> > > This is not file corruption, it sounds like a database century
> > parameter
> > > issue. You set it to 59 and the system defaults larger numbers
to
> 19th
> > > century, lower numbers to 20st century.
> > > Patrick J. Winter
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> > Behalf
> > > Of smj2cool
> > > Sent: Friday, April 11, 2008 7:39 AM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Subject: [SPAM] [Vantage] Employee File Birthdate Corruption
> > > Here's one for the group that I'll bet you've not heard before.
I
> > > discovered that any employee with a birtdate in the 1950's and
> 1960's
> > > has been changed to 2050, etc... This absolutely is not any
type
> of
> > > operator error since most of these birthdates have been set up
for
> > > years. I logged a call with Vantage two days ago but have not
> heard a
> > > peep from them. Just wondering if anyone else has experienced
> > > something like this. This is very disturbing - what if Vantage
> decided
> > > to corrupt the employee rate dates - that would be a horrible
> mess. We
> > > are on v 8.03.404
> > > This e-mail and any attachments may contain confidential and
> > > privileged information. If you are not the intended recipient,
> > > please notify the sender immediately by return e-mail, delete
this
> > > e-mail and destroy any copies. Any dissemination or use of this
> > > information by a person other than the intended recipient is
> > > unauthorized and may be illegal.
