Thank you
This will make the code completion behave.
May help a lot of you.
//If you want proper intellisense
var sb = (ISandbox)Sandbox;
string sampleData = sb.IO.File.ReadAllText(sandboxFile);
The trouble is Kevin isnāt scalableā¦
What happens when Kevin isnāt around?
When you say āfunction code,ā are you referring to an Epicor Function?
If so, or in a BPM, I wonder if you could utilize the Session.AppServerURL?
This is what you want
Thanks Guys for all of your input. I think I finally have this working.
Pick a post and mark it solved.
