Marc-
Better double check the reporting of Section 125 deductions on the W-2s. I
believe these SHOULD BE REPORTED on the W-2s.
Rick Ludwig
Corp. Controller
Metal Spinners, Inc.
Rick Ludwig
Corp. Controller
> From: Marc Durre[SMTP:mdurre@...]
> Reply To: vantage@egroups.com
> Sent: Thursday, September 14, 2000 8:54 AM
> Subject: RE: [Vantage] Special Payroll Deductions
> Steve
> I asked your questions to our payroll guru and received the following
> answers.
> Our cafeteria plan is set to Special Type: Pre-401K Section 125.
> The cafeteria plan deduction is not reported on the W2.
> I hope this helps.
> Marc Durre
> Durre Bros.
> -----Original Message-----
> From: Steve Sanders [mailto:ssanders@...]
> Sent: Wednesday, September 13, 2000 4:30 PM
> Subject: [Vantage] Special Payroll Deductions
> Our company recently changed our health insurance to a cafeteria-style
> plan
> that allows the employee to have their premiums deducted from pre-tax
> earnings. We've created a new deduction master file, and we've figured
> out
> how to get it to be exempt from the right taxes, but I have a couple of
> concerns:
> 1. Should the "Special Type" field be set to something besides None? My
> gut instinct is that it should be, but none of the choices listed looks
> right.
> 2. Will this information have to be reported separately on the W-2? If
> so,
> does this have to be done manually? I can't see how Vantage could do it
> with the way we have to set it up.
> 3. Any other suggestions/comments from anyone already doing something
> similar?
> TIA
> Steve Sanders
> Delta Centrifugal Corp.
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
