Speeding up a Query
It is all too easy to overlink tables in MS Query (I do it all the time!) and it can REALLY increase the processing time required.
Also: Select appropriate date filtering functions and criteria carefully as well as the over all order in which you are stacking multi table/column criteria.
There are also cases where a UNION between otherwise JOINable tables produces faster query results.
If you have a query that just seems to grind to a halt, definitely invest the time to manually attempt optimize the drag and drop auto-generated MS-Query code.
Rob Brown
bbelzer42 <bbelzer@...> wrote:
I use Microsoft Query quite a bit to create reports and pivot tables
in excel.
I have found that some queries take about 5 seconds and some others
can take up to 5 minutes for about 1000 rows of data.
I am currently on v 6.10.535 with Progress 9.1D.
Any help in speeding up my queries would be MUCH appreciated!
Thanks in advance,
Ben
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
in excel.
Thanks in advance,
Ben
There's a whole bunch of things that can affect the speed....I'm not sure about MS Query specifically but few off the top of my head:
1. Always filter/select first on Company code
2. When linking tables always make the first field pair the company code
3. Use all the fields in an index when possible (which will take care of #2 as well)
4. Filter/select, when possible, on index fields first
There are more but doing all the above usually helps a lot in any report writer or query setting.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bbelzer42
Sent: Wednesday, January 02, 2008 11:30 AM
Subject: [Vantage] Speeding up a Query
in excel.
Thanks in advance,
Ben
If you're in a single company do #1 & 2 really make any difference?
Of Todd Caughey
Sent: Wednesday, January 02, 2008 10:39 AM
Subject: RE: [Vantage] Speeding up a Query
#2 as well)
-Todd C.
Behalf Of bbelzer42
in excel.
Thanks in advance,
Ben
YES! Forces the use of the index route for retrieval rather than record by record evaluation.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ken Williams
Sent: Wednesday, January 02, 2008 11:49 AM
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Todd Caughey
#2 as well)
-Todd C.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of bbelzer42
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
in excel.
Thanks in advance,
Ben
Believe it or not Yes!! The Company is always part of the index on the
tables, so even if you only have 1 company, you still need to include
it.
Brandon Murch
WindStone Medical Packaging, Inc.
Supervisor of Information Technology
(406)259-6387
bmurch@...
www.windstonemedical.com
Sent: Wednesday, January 02, 2008 10:49 AM
Of Todd Caughey
#2 as well)
-Todd C.
Behalf Of bbelzer42
in excel.
Thanks in advance,
Ben
Yahoo! Groups Links
Privileged and/or confidential information may be contained in
this message. If you are not the addressee indicated in this
message (or are not responsible for delivery of this message to that person), you may not copy or deliver this message to
anyone. In such case, you should destroy this message and
notify the sender by reply e-mail. If you or your employer do
not consent to Internet e-mail for messages of this kind,
please advise the sender. Windstone Medical Packaging,
Inc. does not provide or endorse any opinions, conclusions
or other information in this message that do not relate to the
official business of the company.
Good to know. I know of at least one situation where I had to create a
relationship and I didn't include the company, I'll have to go check all
my queries now.
Thanks for the tip!
Of Todd Caughey
Subject: RE: RE: [Vantage] Speeding up a Query
-Todd C.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Todd Caughey
#2 as well)
-Todd C.
On
Behalf Of bbelzer42
in excel.
Thanks in advance,
Ben
Yes, because Progress tries to pick an index based on your selection string. It looks for a match going one field at a time and almost all indexes begin with the Company. The UserFile is a table that doesn't even have the Company.
If one of the fields is a flag, like Job Closed, use "... and Job.JobClosed eq Yes" or "and Job.JobClosed eq No" as opposed to simply "and Job.JobClosed" and "and not Job.JobClosed". The latter breaks the index search, the former does not.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, January 02, 2008 9:48 AM
Of Todd Caughey
#2 as well)
-Todd C.
Behalf Of bbelzer42
in excel.
Thanks in advance,
Ben
Yahoo! Groups Links
