Splash Screen Display Time
I have to agree, Epicor needs to fix this. It's as simple as 1-2-3:
HEY EPICOR ARE YOU LISTENING!!!
1) Add a timer control to the main Vantage.EXE file to cycle every 3-5
seconds.
2) Add the following API function to the program:
PROCEDURE FindWindowA EXTERNAL "user32.dll":U:
DEFINE INPUT PARAMETER lpClassName AS CHARACTER.
DEFINE INPUT PARAMETER lpWindowName AS CHARACTER.
DEFINE RETURN PARAMETER hwnd AS LONG.
END PROCEDURE. /* FindWindowA */
3) Then add the following under the timer control:
RUN FindWindowA("ProFrame":U, "System Login":U, OUTPUT Hwnd).
IF Hwnd <> 0 THEN DO:
RUN DestroySplash.
DISABLE Timer.
END.
This is just my 2 cents on the subject.......
Sent: Wednesday, October 09, 2002 2:56 PM
Subject: RE: [Vantage] Splash Screen Display Time
I agree with a simple rule out there that ALL software programs should
display a splash screen while and until the program is done loading.
No matter how long Vantage takes the splash screen should ONLY disappear as
soon as it is ready for a log in and not sooner.
I don't believe letting user's set their own time or even extending the time
of this splash screen will resolve the problem (not to mention this isn't
the "correct" way a splash screen should be programmed in the first place).
Also, the icon should not turn back to a pointer once the splash screen goes
away and Vantage is still sitting there loading (makes users believe the
computer isn't working; therefore, opens yet another session).
IN A PERFECT WORLD: Double-click the Vantage Icon, Splash screen appears
immediately, cursor turns to hour glass, Log in Screen is completely loaded
so it closes the splash screen, mouse turns back to normal pointer.
Just thought I'd add some of my thoughts on this matter as well, since I've
also been requesting this for a long time and "supposedly" they did "fix" it
at one point in a patch but all they did was lengthen the time the splash
screen stays on the screen which "fixes" nothing at all in my book, and
still causes me problems from people opening Vantage 50 times (true story by
the way).
Jessee Holmes
Stremel Manufacturing Company
Sent: Wednesday, October 09, 2002 1:47 PM
To: 'vantage@yahoogroups.com'
Norton Corporate AV and, yes, disabling network scanning and also excluding
the mapped drive helps a lot. Average w/o scanning is 12 sec. which is
still too long for too many people. If the splash would just stick around
15 sec. it might be enough to make them wait.
-Todd C.
Sent: Wednesday, October 09, 2002 1:31 PM
Subject: Re: [Vantage] Splash Screen Display Time
What anti virus are you using? It only takes us 15 sec to log in
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, October 09, 2002 12:40 PM
Subject: [Vantage] Splash Screen Display Time
> There was an inquiring about this a couple months ago but I could find no
> response in the old messages. So here it is again, is there any way to
> lengthen the time the splash screen remains on the screen? It comes and
> goes so much faster than Vantage starts (in 5.20) that users are not being
> patient enough and trying to start Vantage again, and again, and
again.....
> then they get 4-5 login screens all at once. I would like to set it to a
> full minute if I can. Is there a setting in vantage.ini or vantage.vtg?
> Thanks,
> -Todd Caughey
> Harvey Vogel Mfg. Co.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=229441.2397090.3822005.2225242/D=egroupweb/S=17050071
83:HM/A=1189558/R=0/*http://www.bmgmusic.com/acq/ee/q6/enroll/mhn/9/>
<http://us.adserver.yahoo.com/l?M=229441.2397090.3822005.2225242/D=egroupmai
l/S=:HM/A=1189558/rand=141298165>
patient enough and trying to start Vantage again, and again, and again.....
-Todd Caughey
Todd,
This sounds like an excellent suggestion for EPICOR to add ... If you call
it in, get the ID and post it to the list.
I suspect a number of people would happily jump on the bandwagon.
Todd Anderson
Sent: Wednesday, October 09, 2002 11:41 AM
-Todd Caughey
ADVERTISEMENT
<http://rd.yahoo.com/M=212804.2460941.3878106.2225242/D=egroupweb/S=17050071
83:HM/A=810373/R=0/*http://geocities.yahoo.com/ps/info?.refer=blrecs>
83:HM/A=810373/R=1/*http://geocities.yahoo.com/ps/info?.refer=blrecs>
<http://us.adserver.yahoo.com/l?M=212804.2460941.3878106.2225242/D=egroupmai
l/S=:HM/A=810373/rand=265612555>
Matt at Epicor is checking on it. Says he thinks the ability to set the
time went away with 5.0. If he finds no way I'll request it as an
enhancement and get an ID number to share. In the mean time I am going to
make our own version of the splash graphic and (in big letters) advise WAIT
- VANTAGE STARTING - REALLY!. ;)
-Todd C.
Sent: Wednesday, October 09, 2002 11:51 AM
Todd,
Todd Anderson
-Todd Caughey
ADVERTISEMENT
83:HM/A=810373/R=0/* http://geocities.yahoo.com/ps/info?.refer=blrecs
<http://geocities.yahoo.com/ps/info?.refer=blrecs> >
83:HM/A=810373/R=1/* http://geocities.yahoo.com/ps/info?.refer=blrecs
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
l/S=:HM/A=810373/rand=433767483>
again.....
> Thanks,
> -Todd Caughey
-Todd C.
again.....
> Thanks,
> -Todd Caughey
ADVERTISEMENT
Todd,
Two workarounds that may help you for now...
From Help file: "What's new in 5.1" under the section USER MASTER FILE SECURITY:
Allow Multiple Sessions: This setting defaults to Yes, and allows a user account to start multiple concurrent sessions. Checked only during session startup, not during change user ID. Note that security managers can always launch multiple sessions regardless of this flag. This setting is useful in preventing users from launching multiple sessions, and using Vantage and Progress seats.
Session login timeout minutes: This setting defaults to 2 minutes, and pertains to the System Login window. If the window is active for the specified number of minutes without activity, the session is terminated. The .vtg parameter for this is VantageLoginTimeout. A setting of zero means no timeout.
Vantage Help 5.10, Release A
The above two areas would 1. Keep people from logging in more than once. and 2. Close any login windows that remain hidden behind Vantage after a specified period of time.
Troy Funte
-Todd Caughey
ADVERTISEMENT
the way).
Jessee Holmes
-Todd C.
again.....
> Thanks,
> -Todd Caughey
ADVERTISEMENT
