Hi @Isai,
you can split by choosing a delimiter in C# command [yourstring.Split(‘-’)], but this will apply to every segment in your string, if you need to leave some of them together, then you need to decide your rule i.e. logic, in your example you need the last two to stay together so you need to code this in your loop after splitting every thing in list variable, alternatively change its symbol to a different than what you splitting your string by.
