Jose C Gomez
T: 904.469.1524 mobile
Can you use SQL 2014?
My reason for asking….
I was in the beta program for E10 and had an issue with the initial install. I had SQL Server 2012 on Windows Server 2008R2…
Tech said the issue was due to a version mismatch. They recommend matching the version\
Year of SQL with windows server. To my knowledge, Windows server 2014 is not out…
Sent: Friday, August 22, 2014 10:51 AM
To: Vantage
Subject: [Vantage] SQL 2014 E10?
Anyone know if E10 will be fine with SQL 2014? Microsoft is being a bit overzealous in their licencing...
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
They recommend matching the version\Year of SQL with windows server.
That is quite possibly the most ridiculous thing I have ever heard.
Sent: Friday, August 22, 2014 10:56 AM
Subject: RE: [Vantage] SQL 2014 E10?
To: Vantage
Jose C Gomez
Software Engineer
It is in the install guide. I know it sounds crazy but it solved my issue!
Sent: Friday, August 22, 2014 11:12 AM
To: Vantage
Jose C Gomez
Software Engineer
Tom Christie | Information Technology Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Sent: Friday, August 22, 2014 8:14 AM
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
To: Vantage
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
Jose C Gomez
On Fri, Aug 22, 2014 at 12:01 PM, 'Tom J. Christie' tchristie@... [vantage] <vantage@yahoogroups.com> wrote:
Â<div> <p>I hope Windows switches to releasing server on odd years and SQL on even years just to bug Epicor….
Sent: Friday, August 22, 2014 8:14 AMTo: vantage@yahoogroups.com
To: Vantage
Jose C Gomez
Software Engineer
</div> <div style="color:#fff;min-height:0;"></div>
We are running SQL 2014 / Server 2012 in our test environment w/ no issues.
Brenda
Sent: Friday, August 22, 2014 12:14 PM
To: Vantage
Subject: Re: [Vantage] SQL 2014 E10?
What? that is insane what does the Windows Version have to do with SQL... someone was high when they wrote the docs. Sigh
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
Quis custodiet
ipsos custodes?
To:
To: Vantage
Jose C Gomez
Software Engineer
E:
Jose C Gomez
On Fri, Aug 22, 2014 at 12:39 PM, brenda mohr brenda@... [vantage] <vantage@yahoogroups.com> wrote:
Â<div> <p>
Â
Brenda
Â
To: Vantage
Subject: Re: [Vantage] SQL 2014 E10?Â
Â
Jose C GomezSoftware Engineer
T: 904.469.1524 mobileE: jose@...
Â
Â
Â
Â
Â
Â
Quis custodiet ipsos custodes?Â
Â
That is quite possibly the most ridiculous thing I have ever heard.From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Year of SQL with windows server. To my knowledge, Windows server 2014 is not out…From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
To: Vantage
Jose C Gomez
Software Engineer
T: 904.469.1524 mobileE: jose@...<mailto:jose@...>
[Non-text portions of this message have been removed]Â
Sorry if this reply gets duplicated -- had some issues posting to the group...
SQL 2014 works fine with ERP 10.
There are no known issues in using any version of SQL Server 2008 R2 or later with any version of Windows Server 2008 R2 or later. The “matching release years†described in the release requirements simply reflects the configurations Epicor uses for regression testing as well as the rigs we have setup in Product Support to troubleshoot customer problems.
Here are two SQL 2014 issues I recall in 10.0.600, both which (I believe) have since been fixed in 10.0.700.0:
The Enterprise Search installer set the index DB compatibility to an ancient version of SQL that SQL 2014 does not allow. The workaround is to create the DB on another machine (maybe using a Developer license of SQL 2012 R2) and then restoring that DB to your SQL 2014 server.
The process that creates a new company in an existing ERP database may throw timeout errors on SQL 2014. This was diagnosed as a change in the query optimizer that poorly handles functions embedded in WHERE expressions:
Slow in SQL 2014
select * from a where func(a.b) = @c
Fast in SQL 2014
select * from a where a.b = func(@c)
This is generally a bad query design anyway, but SQL 2014 really hates the top example. We’ve patched the query and inspected our code for any other instances in 700 (it’s a very rare pattern in our code). If you need a workaround, just set the DB compatibility on your ERP database to SQL 2012 and the timeouts go away. There are no other side-effects in the ERP system for setting the DB compatibility.
SQL 2014 works fine with ERP 10 (see below about two known issues).
As far as matching the O/S and SQL versions, there are no known issues in using any version of SQL Server 2008 R2 or later with any version of Windows Server 2008 R2 or later. The “matching release years” described in the release requirements simply reflects the configurations Epicor uses for regression testing as well as the rigs we have setup in Product Support to troubleshoot customer problems.
Here are the two issues I recall in 10.0.600, which have since been fixed in 10.0.700.0:
Slow in SQL 2014
Fast in SQL 2014
This message has been scanned for malware by Websense. www.websense.com
SQL 2014 works fine with ERP 10 (see below about two known issues with the ERP 10 GA release).
As far as matching the O/S and SQL versions, there are no known issues in using any version of SQL Server 2008 R2 or later with any version of Windows Server 2008 R2 or later. The “matching Windows/SQL versions†described in the docs simply reflects the configurations Epicor uses for regression testing as well as the rigs we have setup in Product Support to troubleshoot customer problems.
The process that creates a new company in an existing ERP database may throw timeout errors on SQL 2014. This was diagnosed as a change in the SQL query optimizer that poorly handles functions embedded in WHERE expressions:
Slow in SQL 2014
Fast in SQL 2014
Thanks Erik very helpful.
Does the memory tables work with epicor? I saw a demo at insights, just wondering if it has been tested
On Aug 27, 2014 4:42 PM, "Erik Johnson ejohnson@... [vantage]" <vantage@yahoogroups.com> wrote:
Â<div> <p>
SQL 2014 works fine with ERP 10 (see below about two known issues).Â
Â
As far as matching the O/S and SQL versions, there are no known issues in using any version of SQL Server 2008 R2 or later with any version of Windows Server 2008 R2 or later. The “matching release years†described in the release requirements simply reflects the configurations Epicor uses for regression testing as well as the rigs we have setup in Product Support to troubleshoot customer problems.
Â
Â
Â
Â
Slow in SQL 2014
Â
Fast in SQL 2014
Â
Â
Â
