SQL 2017 - Reorganize Index failing : cannot be reorganized because page level locking is disabled
Since we have upgraded to SQL 2017 and Epicor 10.2.200.x, we can’t run the maintenance plan to reorganize indexes. Its failing on different tables with the error: cannot be reorganized because page level locking is disabled.
Anyone seen that before?
example: Executing the query “ALTER INDEX [PK_ABTPostCode] ON [Erp].[ABTPostCode…” failed with the following error: “The index “PK_ABTPostCode” on table “ABTPostCode” cannot be reorganized because page level locking is disabled.”. Possible failure reasons: Problems with the query, “ResultSet” property not set correctly, parameters not set correctly, or connection not established correctly.
Executing the query “ALTER INDEX [IX_APInvDtl_AssetNum] ON [Erp].[APInv…” failed with the following error: “The index “IX_APInvDtl_AssetNum” on table “APInvDtl” cannot be reorganized because page level locking is disabled.”. Possible failure reasons: Problems with the query, “ResultSet” property not set correctly, parameters not set correctly, or connection not established correctly.
Detailed explanations here: Resolve SQL Server Database Index Reorganization Page Level Locking Problem
