SQL infrastructure sizing
Yea, sorry. That's too much for one box. You need segregation.
Service Connect and Vantage are OK on one box.
Of hoomail4me
Sent: Monday, June 21, 2010 4:45 PM
Subject: [Vantage] Re: SQL infrastructure sizing
The modules I listed are the ones mostly likely we will implement. You
mention 64-bit hardware and 24GB RAM but not sure you suggest running
all the modules listed from the one SQL box.
Approximately 75 Epicor 9 users.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
Drecchio" <vic.drecchio@...> wrote:
> 64-bit OS........ 24GB of ram minimum. Not sure how many users you
have
> and what "add ons" you purchased but that's a great starting place.
> Hardware is cheap. Opt for the higher RPM drives.
> Contact Ben Nixon at Epicor to turn your mud into water.
> Vic
Behalf
> Of hoomail4me
> Sent: Monday, June 21, 2010 3:33 PM
> Subject: [Vantage] SQL infrastructure sizing
> Will be implementing Epicor 9.05.6xxx on OpenEdge but it is clear as
mud
> on the SQL horsepower needed for all of the add-ons. Any
> comments/suggestions would be greatly appreciated on hardware
> requirements for an all in one (wouldn't think ideal)or best practices
> to slice and dice the load.
> Replication Server
> Service Connect
> Advanced Print Management Plus
> TIE Commerce eVision
> Portal Server
> SharePoint
> Thanks
Will be implementing Epicor 9.05.6xxx on OpenEdge but it is clear as mud on the SQL horsepower needed for all of the add-ons. Any comments/suggestions would be greatly appreciated on hardware requirements for an all in one (wouldn't think ideal)or best practices to slice and dice the load.
Replication Server
Service Connect
Portal Server
SharePoint
64-bit OS........ 24GB of ram minimum. Not sure how many users you have
Vic
Of hoomail4me
Replication Server
Service Connect
Portal Server
SharePoint
Agreed. You'll probably want a separate 32-bit box for some of these
pieces. I don't think Portal Server runs on 64-bit, for example.
-bws
Of Vic Drecchio
Sent: Monday, June 21, 2010 3:46 PM
Subject: RE: [Vantage] SQL infrastructure sizing
Vic
Of hoomail4me
Replication Server
Service Connect
Portal Server
SharePoint
The modules I listed are the ones mostly likely we will implement. You mention 64-bit hardware and 24GB RAM but not sure you suggest running all the modules listed from the one SQL box.
> Vic
> Of hoomail4me
> Replication Server
> Service Connect
> Portal Server
> SharePoint
> Thanks
75 simultaneous users?
Of hoomail4me
have
> Vic
Behalf
> Of hoomail4me
mud
> Replication Server
> Service Connect
> Portal Server
> SharePoint
> Thanks
And SonicMQ won't run on Server 2008.
Yes, second time I have mentioned this in just the past few minutes, anyone
guess what I ran into a problem with recently?
Brian W. Spolarich
Sent: Monday, June 21, 2010 4:28 PM
-bws
Of Vic Drecchio
Vic
Of hoomail4me
Replication Server
Service Connect
Portal Server
SharePoint
