hello is there anyway to trunk the sql querys in epicor to clear out the tables for better speed as our system monitor is slowing down
Hi, you probably need to clarify a bit more.
so our system monitor and overall perfomance on epicor is really slow before we was sent a query to run in SQL which deletes old tables to free up space in sql
What is your user ratio to app server? Are you running solid state drives on the SQL db?
