We are using SQL transactional replication to maintain a reporting server, works fine. Also works for EPM. Send me an email if you would like to discuss.
--- In vantage@yahoogroups.com, "Ned C." <TechnoBabbly@...> wrote:
> I am just wondering what people running with SQL as their backend are doing
> for SQL to SQL Replication of the Epicor Database out there?
> I have gotten some conflicting information about it and want to get some
> information from people who are actually using it and what you are doing
> with it. The main issue that keeps being brought up in conversations deals
> with Primary Keys in the tables not existing for some of them, therefore
> being a problem with the straight SQL to SQL replication.
> I want to simplify the use of some of the 3rd party products, EPM more
> specifically in this very instance, so that it will have a better, more up
> to date source for the information being used by EPM or any product,
> including eventual SSRS usage.
> The main problem currently is that the system I am working with is trying to
> use the Epicor Replication which relies on Sonic, and the use of an OpenEdge
> product to be replicating data one direction between SQL databases is just
> completely ridiculous and inefficient. The fact that the replication doesn't
> work properly only makes the issue worse.
> Right now there is a manual backup and restore that is being done to the
> secondary server for "data replication".
> And with a separate but related issue maybe someone has dealt with, I have
> tried scripting a backup and restore, but the restoration "WITH MOVE" of
> Full Text Catalogs files to a new file location has been a sticking point,
> and wondering if anyone else has worked through something similar.
