SQL TRIGGER with 4GL STOP CONDITION HELP
Sean,
Thanks.... I see the problem... I was staring at the statement so long i missed the error (Select from selected....) It should say select from inserted)
Appreciate the help
--- In vantage@yahoogroups.com, "Sean McDaniel" <smcdaniel@...> wrote:
> I might be missing something, but I'm not sure why your trigger would be
> trying to return a value.
> Typically your trigger would update the inserted.<column>
> Typically I'd try an insert of my own within SQL to see what happens.
> Of Joshua
> Sent: Thursday, May 27, 2010 9:20 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] SQL TRIGGER with 4GL STOP CONDITION HELP
> So I'm attempting to run a trigger on the Jobmtl Table.
> The trigger purpose isn't important at this time because I'm getting
> this 4GL stop condition error in Epicor.
> Eventually the trigger will grab the Vendor Part from the Vendpart table
> and update a character field in the Jobmtl table so that engineers can
> have access to the the vendor part#.
> The trigger at the moment just grabs the part from the Inserted Record.
> Thats it. Every time i add a record in Epicor i get the 4GL STOP
> CONDITION ERROR. The trigger is run outside of EPICOR how and why would
> Epicor be giving an Error. Especially if the Trigger was After the
> Insert..
> here is the trigger code.... (on the JOBMTL Table)
> ALTER TRIGGER [VENDOR_PART]
> ON [dbo].[jobmtl]
> AFTER UPDATE, INSERT
> AS
> DECLARE @partnum varchar(50)
> BEGIN
> select @partnum=partnum from selected
> END
> Any help on this would be greatly appreciated....
The trigger purpose isn't important at this time because I'm getting this 4GL stop condition error in Epicor.
Eventually the trigger will grab the Vendor Part from the Vendpart table and update a character field in the Jobmtl table so that engineers can have access to the the vendor part#.
Thats it. Every time i add a record in Epicor i get the 4GL STOP CONDITION ERROR. The trigger is run outside of EPICOR how and why would Epicor be giving an Error. Especially if the Trigger was After the Insert..
ON [dbo].[jobmtl]
AS
BEGIN
END
Of Joshua
Insert..
ON [dbo].[jobmtl]
AS
BEGIN
END
Hi
You can't use the statement
try this
select @partnum=partnum from inserted
Stelios
Stelios Zoumis
Senior ERP Consultant
ATC S.A. Financial Products & Solutions Department
Tel: +30 210 6874300 Fax: +30 210 6855564
10, Rizariou str, 152 33 Halandri, Athens, GREECE
E-mail <<<mailto:s.zoumis@...<blocked::blocked::mailto:s.zoumis@...>>>>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua
Sent: Thursday, May 27, 2010 4:20 PM
ON [dbo].[jobmtl]
AS
BEGIN
END
You can also check the Server Logs when you get those 4GL Stop Condition Errors. There will be a more detailed explanation of what the problem is that is very useful in troubleshooting.
--- In vantage@yahoogroups.com, Stelios Zoumis <s.zoumis@...> wrote:
> Hi
> try this
> Stelios
> Stelios Zoumis
> ON [dbo].[jobmtl]
> AS
> BEGIN
> END
