Squirrel set up problems
Worked beautifully. Thanks Vic!
On Mon, Jun 10, 2013 at 4:24 PM, Vic Drecchio
<vic.drecchio@...>wrote:
> Hey Jeff,
> http://tech.groups.yahoo.com/group/vantage/files/ODBC/
> Open the 2nd doc listed there: ODBC Epicor Vantage 803 Setup.pdf
> Step through the first page or two and it walks you through how to change
> ODBC security on the Progress back-end.
> Of
> jeff
> Sent: Monday, June 10, 2013 3:53 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Squirrel set up problems
> I downloaded and set up squirrel to connect to progress via the directions
> provided by Vic. I was able to browse the tables and values in the training
> db. I've created an alias for Test but am getting an authentication error
> when using sysprogress/sysprogress. I can change it to use the manager id
> and it then connects to the db and let's me see all the tables. Problem is
> that it doesn't return any of the values in any of the table once again
> giving my a authentication error. Is there some place I can reset the
> sysprogress pw or some other "switch" I may be missing? Thanks.
Jeff Purvis
J&T Distributing
859-745-7956
www.jtfoc.com
I downloaded and set up squirrel to connect to progress via the directions provided by Vic. I was able to browse the tables and values in the training db. I've created an alias for Test but am getting an authentication error when using sysprogress/sysprogress. I can change it to use the manager id and it then connects to the db and let's me see all the tables. Problem is that it doesn't return any of the values in any of the table once again giving my a authentication error. Is there some place I can reset the sysprogress pw or some other "switch" I may be missing? Thanks.
Hey Jeff,
jeff
