SSRS Error when adding condition
I modified the customer statement to only show Open Invoices but am getting an error “Query execution failed for dataset 'Customer_InvcHead_CashDtl_RptLabel” when I add the condition
AND T2.OpenInvoice = 1
If I remove the condition I get no errors.
=“SELECT
T1.Terms_Description,
T1.RptLanguageID,
T1.CustID,
T1.EMailAddress,
T1.FaxNum,
T1.Calc_AgeLabel1,
T1.Calc_AgeLabel2,
T1.Calc_AgeLabel3,
T1.Calc_AgeLabel4,
T1.Calc_AgeLabel5,
T1.Calc_AgeLabel6,
T1.Calc_BillToAddress,
T1.Calc_BTContactName,
T1.Calc_StatementComment,
T1.Calc_StatementDate,
T1.SalesRep_EMailAddress,
T1.SalesRep_FaxPhoneNum,
T1.SalesRep_Name,
T2.CustNum,
T2.Company,
T2.CurrencyCode,
T2.DebitNote,
T2.CreditMemo,
T2.DNCustNbr,
T2.DocInvoiceAmt,
T2.DocInvoiceBal,
T2.DocWithholdAmt,
T2.DueDate,
T2.InvoiceDate,
T2.InvoiceNum,
T2.InvoiceSuffix,
T2.PONum,
T2.Calc_CurrSymbol,
T2.CurrencyCode_CurrDesc,
T2.InvoiceType,
T2.Calc_CheckRef,
T2.OpenInvoice,
T3.Company as CashDtl_Company,
T3.CheckRef,
T3.DocTranAmt,
T3.InvoiceNum as CashDtl_InvoiceNum,
T3.InvoiceRef,
T3.TranDate,
T3.TranType,
T3.CustNum as CashDtl_CustNum,
T3.Calc_DisplayAmount,
T3.Calc_Reversed,
T3.Calc_IsCM,
T3.Calc_DocDtlTranAmount,
T3.Calc_DocDtlTranAmountSignAdjusted, ISNULL(T3.Calc_Charge,T2.Calc_Charge) as Calc_Charge,
ISNULL(T3.Calc_CMemo, T2.Calc_CMemo) as Calc_CMemo,
T3.Calc_TranType,
T3.Calc_PayRef,
T4.DueDate as RptLabel_DueDate,
T4.RptLiteralsLBalanceDue,
T4.RptLiteralsLCharge,
T4.RptLiteralsLCheck,
T4.RptLiteralsLCredit,
T4.RptLiteralsLDate,
T4.RptLiteralsLEmail,
T4.RptLiteralsLFax,
T4.RptLiteralsLInvoice,
T4.RptLiteralsLPage,
T4.RptLiteralsLPO,
T4.RptLiteralsLSubTitle,
T4.RptLiteralsLTotal,
T4.SalesRepCode as RptLabel_SalesRepCode,
T4.RptLiteralsLPayInv,
T4.RptLiteralsLAdjust,
T4.RptLiteralsLCMemo,
T4.RptLiteralsLPayInvReverse,
T4.RptLiteralsLPhone,
T4.rptliteralslof,
T4.RptLiteralsLPIID,
T4.RptLiteralsLPIType,
T4.RptLiteralsLPIStatus,
T4.RptLiteralsLPIDueDate,
T4.RptLiteralsLPIAmount,
T4.RptLiteralsLPIOutstandingAmt,T1.Calc_ContactEmailAddress,T1.Calc_ContactFaxNum,
(CASE WHEN EXISTS(SELECT TOP 1 ARPromNoteID FROM ARPNHead_” + Parameters!TableGuid.Value + " WHERE CustNum = T2.CustNum AND CurrencyCode = T2.CurrencyCode) THEN 1 ELSE 0 END) as PaymentInstrumentsExists
FROM Customer_" + Parameters!TableGuid.Value + " T1
LEFT OUTER JOIN InvcHead_" + Parameters!TableGuid.Value + " T2
ON T1.Company = T2.Company AND T1.CustNum = T2.CustNum
LEFT OUTER JOIN CashDtl_" + Parameters!TableGuid.Value + " T3
ON T2.InvoiceNum = T3.InvoiceNum
LEFT OUTER JOIN RptLabels_" + Parameters!TableGuid.Value + " T4
ON T1.RptLanguageID = T4.RptLanguageID"
watch for whitespace at BOL or EOL especially for the lines you MUST have one or the other:
InvcHead.OpenInvoice is a yes/no field in the data dictionary. Try “T2.OpenInvoice IS TRUE” or “T2.OpenInvoice = -1”?
You can’t add a condition “AND …” without previously using “where”. If you already have a condition (or more) then you can use ‘AND’ and add another one. But if you don’t, you start with WHERE. So try “WHERE T2.OpenInvoice = 1”
Try this:
="SELECT
T1.RptLanguageID,
T1.CustID,
T1.EMailAddress,
T1.FaxNum,
T1.Calc_AgeLabel1,
T1.Calc_AgeLabel2,
T1.Calc_AgeLabel3,
T1.Calc_AgeLabel4,
T1.Calc_AgeLabel5,
T1.Calc_AgeLabel6,
T1.SalesRep_Name,
T2.CustNum,
T2.Company,
T2.CurrencyCode,
T2.DebitNote,
T2.CreditMemo,
T2.DNCustNbr,
T2.DocInvoiceAmt,
T2.DocInvoiceBal,
T2.DocWithholdAmt,
T2.DueDate,
T2.InvoiceDate,
T2.InvoiceNum,
T2.InvoiceSuffix,
T2.PONum,
T2.Calc_CurrSymbol,
T2.InvoiceType,
T2.Calc_CheckRef,
T2.OpenInvoice,
T3.CheckRef,
T3.DocTranAmt,
T3.InvoiceRef,
T3.TranDate,
T3.TranType,
T3.Calc_Reversed,
T3.Calc_IsCM,
 Calc_Charge,
T3.Calc_TranType,
T3.Calc_PayRef,
T4.RptLiteralsLFax,
T4.RptLiteralsLPO,
T4.rptliteralslof,
You can use conditionals in a Join statement.
It just becomes a criteria on the table.
Absolutely! You would need to make sure you add it in the correct join, and not just at the end of the query.
That worked! Thank you!
And whitespace was this issue all I did was ensure there was a space at the start of each line for your original post and put into code block.
