SSRS Error
In this report I am trying to do this Expression Sum(Fields!Custom_Total.Value). Which is Sum(IIf(Fields!Part_NonStock.Value=True,Fields!OrderDtl_DocExtPriceDtl.Value,0)). SSRS keeps telling me in the printed report, error. So I looked at it in Even viewer and found this error.
net.tcp://e10/erp10/: System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:05:00'. ---> System.IO.IOException: The read operation failed, see inner exception. ---> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:05:00'. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host    at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)    at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing)    --- End of inner exception stack trace ---    at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing)    at system.ServiceModel.Channels.SocketConnection.Read(Byte[] buffer, Int32 offset, Int32 size, timeSpan timeout)  at System.ServiceModel.Channels.DelegatingConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)  at System.ServiceModel.Channels.ConnectionStream.Read(Byte[] buffer, Int32 offset, Int32 count)   at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)    at System.Net.Security.NegotiateStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)    at System.Net.Security.NegotiateStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)    --- End of inner exception stack trace ---    at System.Net.Security.NegotiateStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)  at System.Net.Security.NegotiateStream.Read(Byte[] buffer, Int32 offset, Int32 count) at System.ServiceModel.Channels.StreamConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)    --- End of inner exception stack trace ---
Server stack trace:
   at System.ServiceModel.Channels.SessionConnectionReader.Receive(TimeSpan timeout)
   at System.ServiceModel.Channels.SynchronizedMessageSource.Receive(TimeSpan timeout)
   at System.ServiceModel.Channels.TransportDuplexSessionChannel.Receive(TimeSpan timeout)
   at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceive(TimeSpan timeout, Message& message)
   at System.ServiceModel.Channels.SecurityChannelFactory`1.SecurityDuplexChannel.TryReceive(TimeSpan timeout, Message& message)
   at System.ServiceModel.Dispatcher.DuplexChannelBinder.Request(Message message, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
   at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
   at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   at Ice.Contracts.SessionModSvcContract.Login()
   at Ice.Proxy.Lib.SessionModImpl.Login()
   at Ice.Core.Session..ctor(String userID, String password, String asUrl, LicenseType licenseType, String pathToConfigurationFile, Boolean fwVerCheck, String companyID, String plantID)
   at EpiSSRSService.ReportMonitorAgent.timer_Elapsed(Object sender, ElapsedEventArgs e) in c:\_projects\ICE3\2012RCurrent\Source\Client\SSRS\EpiSSRSService\ReportMonitorAgent.cs:line 122
Are you sure that is related to your report and not a random socket timeout complaint? If it is related, did you make the join to get this data? Is this based off of a system report? If so does it still work?
Does the data get created in the temporary table in the reports database?
What does the MSRS log say? I would imagine there would be something more intuitive there than the event viewer.
Not sure what you are referring too…
Sorry. It’s the Microsoft SQL Reporting Service log, on your SQL server.
try replacing the zero with nothing
Sum(IIf(Fields!Part_NonStock.Value=True,Fields!OrderDtl_DocExtPriceDtl.Value,Nothing))
